Hesson 1014 Haybine and HP
   / Hesson 1014 Haybine and HP #1
bruwen811
White 1470
I can buy a Hesston 1014 Haybine, does any one know how HP you need to run this machine
Thanks
Thanks for the info, how did the swing draw bar work
   / Hesson 1014 Haybine and HP #4
Once you use a center pivot machine you will never want to go back to a side pull unit. period.
   / Hesson 1014 Haybine and HP #5
Ain't that the truth!.
However i installed a restrictor in the swing cyl lines to slow down the swing speed switching from side to side.
   / Hesson 1014 Haybine and HP #6
I have to disagree. I have both, a Kuhn center pivot and a JD side pivot and each have their strong points, depending on field accessability and shape.
The 1014 that I bought is a 10ft version and has the semi side pivote, how is it different than a center pivote
   / Hesson 1014 Haybine and HP #8
To each his own. I never encountered a field that wasn't easier to mow with a center pivot than not.
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
2022 John Deere 8R 340 MFWD Tractor (A53342)
2022 John Deere 8R...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
