2520 popping out of 4WD
   / 2520 popping out of 4WD
Hi Gobblin Tom,
360 hours on my 2520 and almost 5 years old.
I've never had my tractor pop out of 4wd once it was engaged.
I have had a heavy load (61" bucket full of t-pak) in my bucket going down a hill to lay material for a boat launch.
I use both my 4wd & diff. lock often. I have a very wet spot in my yard that I mow over and when coming up to it I engage 4wd on the fly with my foot and have my heel on the diff. lock once I start to feel the rear wheels slipping. Once throught the wet spot, the diff lock pops up naturally and then I use the heel of my foot to pull up on the 4wd lever to put it back in 2wd on the fly.
If your tractor is in warranty, it's a no brainer...call the dealer.
If not, I'd pony up and have the tractor serviced and have this fixed ASAP as it sounds like you have a possible safety hazard.
When you said you had to drop the bucket quickly to slow yourself down...did you forget to mention that you probably "pooped your pants" right before you dropped the bucket:laughing:?
The tractor only has 34 hours on it and yes it would be covered under warranty. The 1st time it caught me a little off guard but from there I knew to watch for it, I am not one to panic under pressure so it didn't give me a skid mark or anything... LOL:ashamed:
Hey Tom,
Man,sorry to hear you're having another problem.
From what guys have said,I too actually "feel" it click or indent or whatever you would call it. It doesn't do a serious lock per say like your range lever does. It is ....I guess subtle,but you can still feel it.
Here are a couple pics with where the lever is engaged and disengaged.
Greg
Thanks Greg, my lever feels like it is switching (by hand it feels like it, can't tell with my foot) but just not staying engaged when it has a heavy load on it. It didn't pop out every time but when you are unsure it makes you uneasy.. I worked hard to get this tractor and it took a long time for me to finally get it. I never expected to have even a small problem let alone something that seems hazardous.. I think I will have Robert at VD call a rep and inquire, seems like that would be the smart thing to do??
Hey Tom,
Greg
Mine is reading the same as yours with the tape....
   / 2520 popping out of 4WD #24
Tom,
I just checked how the feel was moving the lever in and out of 4WD. It moves relatively easy but does definately click/engage in both positions.
   / 2520 popping out of 4WD #25
With only 34 hours on it, Deere will no doubt make this right for you.
Nothing is perfect and everything breaks.
Once they fix this, you will learn to trust it and you will love it.
Please let us all know how you were treated and the final outcome.
   / 2520 popping out of 4WD #26
So, are you sure that it has been going all the way into 4WD? My 4WD light comes on when I barely move the lever down but it is not engaged until it is all the way down. I definately can feel the engagement. Good luck and let us know as I sure wouldn't want to experiance this.
So I put a call back into the dealer this morning, he said he was going to check with the service manager and get back to me. I asked if he was going to contact a JD rep and he said not yet until he talks to the service manager. I would have thought with a safety concern like that he would let someone at JD know??? I guess time will tell... It don't look like I will be using it much this week anyway with all the rain and work schedules....
   / 2520 popping out of 4WD #28
I think it's typical for the dealer to trouble shoot this before they make a call to the John Deere factory representative. It's no different than if your transmission had problems in a GM pickup truck, and you took it to a GM dealer/service center the dearler would trouble shoot it before contacting a GM rep. Your Deere dealer and their service techs are trained or have the service manuals available to them to solve these problems. If they cannot...then they are going to call a John Deere rep.
Even though we all think our problems are big problems, the dealer is going to take it in stride with the many problems they fix everyday. I am sure your problem will be solved....after all, your tractor has the highest looked upon and prestigeous name/logo on the hood....John Deere.:D
   / 2520 popping out of 4WD #29
Tom I'll be glad (and so won't you) when you have the little bugs worked out so you can then help me with my new 2520 that's expected to arrive anyday.
   / 2520 popping out of 4WD #30
From what I can see in the service manual, all the lever does is move a collar to engage two splined shafts that are piloted together.
The output shaft has a hole drilled through the splines where the collar slides. In the drilled hole, there is a spring and two balls that act as a detent for the collar. It all looks pretty simple, but you have to disassemble the transmission to get to these parts. I'm guessing that the spring or balls are missing. That would certainly explain your problem.
Yeah that's interesting, I hate to have anything new taken apart like that but I guess I have no choice if that what it comes too! I have yet to hear back from the dealer....
   / 2520 popping out of 4WD #32
So you say that you think he may be missing is balls?
Sorry, just couldn't resist.
   / 2520 popping out of 4WD #33
That's funny BRBurns, but your right.
There is nothing worse than needing balls for an operation...and having none!:laughing:
Talked to the dealer today, he said they will have to take the tractor apart and see what the problem is, he said it is definitely internal and should not be popping out. They will have it around 7-10 days he said. I told him I will wait until my rear chains come in and my brush guards for the lights that way they can do everything at once. Maybe I will have my 50hrs on by then and they can do the 1st service also..... Chains are supposed to be in july sometime...:cool:
   / 2520 popping out of 4WD #36
Such a shame to pay a dealer their prices for routine maintenance. Unless JD is better about than my Kubota dealer, $250 to change fluids and sharpen the blades plus $50 to come and get it.
   / 2520 popping out of 4WD #37
"".......this other lever with the knob on the end does not feel like it locks into anything solid.""
I had exactly the same problem on an older different model tractor a couple years ago. I spoke to the service guy and he explained what probably happened and how to fix it (mine wasn't under warranty). It was quite easy to fix w/o completely disassembling the transmission. On mine, there was a spring loaded ball that moved to detents to hold the lever in either ON (engaged) or OFF (disengaged). According to the service guy who claims he has seen this numerous times is what happens is when the lever is moved beyond the detent positions the ball pops out and down into the transmission. I drained the oil out of my transmission and found the ball. I removed a small side plate on the transmission near the control lever and put the ball back in place --- problem fixed.
Your 2520 may be very similar.
From what other had said that might be true, I could only hope that there is not any damage being caused to the transmission if this were to be true.... How did you get it to stay in and not do that again? The 2520 is a foot activated lever so I can't see how it could go past a certain point? I just get the feeling my tractor was built on a Monday or Friday..:(
   / 2520 popping out of 4WD #39
Hey Tom
I wouldn't do that.That may have been your problem in the first place,too much down pressure with your foot.
I know there are probably owners that do this all the time with no problems, but the lever has a knob on it,and I would look at that as something to be moved with your hand. IMO, if it was meant to be moved with your foot it would be designed differently.
Hey,maybe I'm full of it,but that's my .02.:)
Greg
Hey Tom
Greg
Yeah I guess that could happen but they (dealer and JD) all said it was a foot activated lever even in the videos from john deer. I don't ever remember pushing it that hard but I guess it would be easy to do. I will have to ask again but I might have to use the hand method as you do, once its fixed.... I guess I just never expected it to bt that fragile, I expected more like bullet proof....
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2022 KOMATSU PC360LC-11 EXCAVATOR (A60429)
2022 KOMATSU...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Bobcat S740 (A57148)
