TRACTOR WEIGHTS
   / TRACTOR WEIGHTS #1
gunnner
GRAHAM CO. N.C.--Elv. 3150'
Yanmar 1610 2X4 tractor---Kabota B 2320 4X4 7 Kobelco SK015 Excavator
Do any of you use weights on the front of your tractors.
I maintain 1 mile of gravel road----all uphill ( lessin ya goin down LOL).
When pulling gravel up hill I think I need more traction from the front wheels. Also---The other day the front reared up---wheels off the ground---YIKES.
I see that tractor weights are very expensive from Kubota & they tell me I need a special bracket to mount weights.
How bout home made ones????
My tractor-----Kubota B2320---no FEL on it
   / TRACTOR WEIGHTS #2
When I bought my 2320 JD, I worked 5 (210#) of weights into the deal. I bought a 60" RFM and didn't want the loader on for mowing so I knew that front weight were going to be a necessity. In all honesty i still need 2 more and the bracket that goes with them. with th mower raised and 3 weights on the frontend I can lift the frontend of the tractor off the ground by hand and with 5 it is a little light in some circumstances.
   / TRACTOR WEIGHTS #3
i cast some concrete weights and hung them on the front of my ford 4600 I mow with as I have to trailer up a steep incline and with a hd 6' mower on the back it was getting a lil soft in the front.
soundguy
   / TRACTOR WEIGHTS #4
I have a Jinma 284 with both a FEL and suitcase weights on the front. I have 4 weights and I think they are 35# each or so. They really seem to help it steer in the snow.
My tractor is a little bigger than yours, about 5500# with me on it and something on the 3 point, but I am sure it will help yours also.
In my opinion your issue is no FEL. These tractors are made to have loaders and the balance is all off if not equipped with one.
Chris
   / TRACTOR WEIGHTS #5
I have both front and rear weights on my oliver, i have the heavy grill which is 300pounds, the weight hanger which is at least another 100 and two 150+pound plates. Also i have the loader on as well, and some times when i am mowing i still dont have enough front.
When i am using it as a loader tractor, i have a full set of wheel weights that never come off and i still see my rear wheels coming off of the ground. I had to put a bale on the back.
I can run more weight in the front but it blocks the grill and causes and over heat. I would make a bracket that goes on the front and have a steel box made out of 3/8 plate and fill it with lead. Any one have a weight of concrete vs lead on a ci basis?
   / TRACTOR WEIGHTS #6
On my yanmar ym2000 (similar in size to a JD 850) I have almost 200lbs on the front. I had a solid 3" round stock steel piece welded to some angle iron to make a bracket to hold it on. Its around 40" wide. That wasent enough so i cut about a 30" or so hollow 3" ID steel pipe and had it filled with lead then welded to the same brackets. This new addition was tipping the scales at ~100lbs. That with the old piece which was around 75lbs is just about the right weight although id like another 50. With my disk harrow and a few hundred pounds on it its still light in front.
   / TRACTOR WEIGHTS #7
All of my tractors except the Duetz have come with weights on the front. I removed them from the Steiner (actually rear weights) and my JD2555, but still have them on the Ford 7710 to offset the weight of the boom mower. I think there are 13 weights plus the heavy mounting bar and it still isn't enough. Only takes extending the boom rearward to send the front end skyward.
David from jax
   / TRACTOR WEIGHTS
As nwngunner asked---
"Any one have a weight of concrete vs lead on a ci basis?"
Well I did some lookin----
The density of lead is abt 11340kg/m3...
and of concrete is abt 2400 kg/m3
for a fixed volume and shape...i guess lead is at least 4 times heavier...
The main problem with concrete is that is is so much less dense than lead or cast iron.
This means that to have the same weight you will need approximately 5.5 time more volume of concrete than lead.
The usual method for increasing the weight of the concrete keel is to add scrap iron into the mix.
But even with scrap you will still need somewhere in the region of two to three times the volume of a lead keel.
HTH----gunnner;)
   / TRACTOR WEIGHTS #9
I think the correct way to add weights to a tractor is simply add a piece of railroad track to the front, in whatever lenght you can find or purchase (don't steal them, it makes too big a mess when the train finds the missing section). For larger tractors, stacking tracks a couple high seems to work, or putting them in front of each other. I prefer the bottom to bottom bolted together method.
David from jax
   / TRACTOR WEIGHTS #10
As stated above, lots of ag tractors carry cast iron weights on the front for ballast. Just a few years ago many of the farmers would put large Rock Boxes on the front of the tractors in oder to pick up the occasional rock out in the field.....but many put the rock boxes on as an afforadable way to add front ballast to the tractor too. Rocks and gravel are inexpensive mass. :thumbsup:
Maybe your tractor could be fitted with a front rock box?
   / TRACTOR WEIGHTS #11
I put 4 kubota weights on the front of my 3240 and it makes all the difference in the world. It could actualy use a few more but with the bumper I have 4 is all that fits... Its the only weight (way) to go... I think the weights are 52lbs each and bumper weighs about 50lbs?
AndyG
   / TRACTOR WEIGHTS
Looks like those weight are hangin low---decreasing your ground clearance---& that is something I need up here in the woods.
Also I notice that bumper to hold the weights---I mean is that necessary---I know thats what my Kubota dealer suggested-----BUT:confused:
   / TRACTOR WEIGHTS #13
The front of the frame on the B-series is designed to accept 3 weights without a bracket. If you want to hang a full set (5) you need to get the bracket. The weights should be about a dollar a pound, if they are much more than that the dealer is ripping you off. Start with 3 and I bet that will make a big difference.
I wouldn't expect to find weights for much cheaper than $1/pound however, most tractor weights regardless of type, size, or make sell for about that.
Oh, and they won't decrease your ground clearance much at all. They hang down some but still are not the lowest point under the tractor (above pic is an optical illusion.)
   / TRACTOR WEIGHTS #14
Never really thought about it but it does take some clearance. I measured about 2-3 inches in the front but almost same as the lowest point on the tractor.. I tooks some pics to show if that helps??
AndyG
   / TRACTOR WEIGHTS
Well now----I called my Kobuta dealer about weights---He did say that it would hold 3 without the extra bumper---
However---they are $92 for 55#-----Huuuummmmmm ?
I don't know of another place to get them around here---I live far from any big city.
Also I wonder if I did find another place to purchase them----Would they bolt rite up---are there diff. bolt hole configurations?
Thanks for all the replies :thumbsup:
   / TRACTOR WEIGHTS #16
HTH----gunnner;)
and the main plus to concrete is you can cast it yourself, easilly, and it's super cheap.
I can hang as much concree weight on the front of my tractor to do the work for about 20$ of materials, vs 200$ of suitcase weights.
ok.. so they are a lil bigger.. but then.. so is my wallet at the end of the day...
money is worth more to me than bragging about having a metal weight.
soundguy
   / TRACTOR WEIGHTS #17
Not sure the bolt size or confg on your tractor? But wow $92 is high. I got 3 on mine when I bought it and added another later- the one I added was $57 Kubota weight #502 on the side of it.. I think it weighs 52-55 lbs...
   / TRACTOR WEIGHTS
   / TRACTOR WEIGHTS #19
soundguy
Nicely played :thumbsup:
   / TRACTOR WEIGHTS #20
i know some people have to have oem parts emblazoned with their brands logo and whatnot at 2-5x the cost.. .. um.. I just want the weight. add a few minutes work and some black paint and at 10' away it's hard to tell my cast concrete weights aren't cast iron weights due to texture, etc.
soundguy
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56438)
Bulk Lot of over...
2021 CATERPILLAR 299D3 XE SKID STEER (A60429)
2021 CATERPILLAR...
43023 (A59228)
43023 (A59228)
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
