number two
- Joined
- Apr 2, 2007
- Messages
- 1,398
- Location
- Northern Lower Michigan
- Tractor
- Kubota B3030HSDC Kubota L2501HST
[quote=Chilly807;2436891]This reminds me of the movie "Groundhog Day" with Bill Murray, where he keeps reliving the same day over and over.. this thing just keeps coming back, like a cat.
Much as I'd like to see this issue solved, you have the easiest option of all.
Take Kubota up on their offer of a refund, and be done with them. Deere, New Holland and others make good tractors without this frustrating problem. They didn't get to be the size they are by building inferior machinery. I'm brand loyal to Kubota in most things, but the 3-point thing isn't one of them.
If they've exhausted all the avenues they're willing to go down, then anything you try may void your warranty.
Mine is jumpy too (2009 L3400), but not bad enough that it overshadows everything else the tractor does so well. I've got a few ideas about how to fix it, but I'll wait until the warranty is over before I try it. And I'll have to have time on my hands, and nothing better to do, so this may take a while...
Good luck, let us know what you decide to do.
Sean
kubota dealers should be required to do the same thing to everyone buying an L2800-L3800 tractor. Then have the buyer sign a waiver saying they are fine with it... :2cents:I forgot to mention that yesterday my dealer hooked up a 6' heavy box scraper up to a B3030. Using the position control lever, it was silky smooth going up and down...
Dumb question but.... If this is a flow issue idling the tractor down should make a significant difference Vs running 1/2 to 3/4 throttle. Just out of curiosity has anyone tried this? Not a solution but might point towards a possible cause and or potential solution.
I know on my little BX the faster the engine speed the quicker the lift so i would presume similar results with an "L" series but I have driven one so don't know for sure.
Roy
They are on the youtube link above, under my name... not with the spray rig but others. Just as jerky... almost as if they went out of their way to make it that way... sorry my conspiracy theory pops out every once and a while...Dumb question but.... If this is a flow issue idling the tractor down should make a significant difference Vs running 1/2 to 3/4 throttle. Just out of curiosity has anyone tried this?...
