Finally got me a REAL Truck
   / Finally got me a REAL Truck #81
AGGIE00 said:
Have you owned one? There is no comparing the six speed auto that comes with the 6.7 to the old. I would never go back to the 5.9 after owning my 6.7 that now has 140k on the dial in only 3 years and has only needed two u-joints, brake pads and an evaporator core. By far the best value truck I have ever owned and is still strong and tight in the front end. The 5.9s I have been around spit out transmissions like I go through brake pads.
I have driven both the 5.9 and 6.7 but have not owned either one. I agree the 6.7 with the 6 speed is a great combo, but the added emissions equipment and EGR would keep me from buying one. I would not be willing to take the risk or hassle of removing the factory emissions equipment.
   / Finally got me a REAL Truck #82
Geno's Garage describes what I cannot: "The drivers side front wheel is permanently connected to an axle shaft which runs to the differential. The passengers side has a two piece axle, one half permanently connected to the wheel, one half (intermediate axle shaft) connected to the differential. The two halves meet in the middle of the passenger side axle tube (that bulge on the axle tube is where the axle disconnect lives). The two halves are connected together for 4X4 operation by the Center Axle Disconnect mechanism."
This is what I was incorrectly referring to that causes the left side to wear faster than the right. I'll agree it's poor engineering and/or cheap manufacturing, but the results still end up as ball joint replacement at fairly regular intervals.
Joe
Hmmm I don't know about this. My truck only disconnects at the transfer case. It has no other disconnect in on the axle. I'm gonna look at my truck again. Maybe this is only on push button 4wd?
   / Finally got me a REAL Truck #83
I second that. Emission controls are lame when they make the vehicle burn more fuel than a non equipped vehicle! Whats the point? Isn't total emission output still roughly the same?! I bet the oil companies love the new fuel hungry emission control systems!
   / Finally got me a REAL Truck #84
Those are for the older Dodge with a Dana axle. The 2003 and up with the American Axle disconnect in the transfer case.
   / Finally got me a REAL Truck #85
OK, so now I'm really confused. Why then, on the 2003 and up, does the driver's side ball joint still tend to wear faster than the passenger's side? :confused::confused2::confused3:
Joe
   / Finally got me a REAL Truck #86
Joe
I don't know, the only 2 repairs I've had on my 2003 2500 with 147K are one rear u-joint and the reverse light switch.
   / Finally got me a REAL Truck #89
99% of the posts on this and most other forums are useless and pointless.
I'd hotly contest that number with you.
there are plenty of forums that while not strictly topical, have pretty good content. many of the antique tractor boards I'm on are directly responsible for keeping a good many hundred or thousand antique tractors running day to day.
soundguy
   / Finally got me a REAL Truck #90
soundguy
I fully agree with you Soundguy...These threads do wander sometimes, but they generally don't get too far off..That's the nature of the beast...This would happen on a real front porch over a couple of beers..Not that I know this from experience or anything.:D
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2356 (A58376)
2356 (A58376)
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
Informational Lot - Shipping (A56436)
Informational Lot...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2018 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2018 Ford F-550...
