Has anybody on TBN ever used a B-Kubota w/o loaded tires?
   / Has anybody on TBN ever used a B-Kubota w/o loaded tires? #31
I have a B2620 unloaded tires I keep the BH on loaded tires are not recomended with BH attached .
   / Has anybody on TBN ever used a B-Kubota w/o loaded tires? #32
I had a B8200HSTD for 12 years. I never filled the back tires. But, I always had something on the back; mower or scraper mostly. Never had any need.
   / Has anybody on TBN ever used a B-Kubota w/o loaded tires? #33
My B7610 has unloaded tires. I use chains in the winter when necessary and it works great.
Ditto - also chains in mud. However I do "semi-load" with slime and carry a BH or a BB :)
And as far as blacktop - all the blacktop I go on is the public road when I'm clearing snow off it because the plows don't come around. Is the blacktop going to hurt the chains or the tractor?
   / Has anybody on TBN ever used a B-Kubota w/o loaded tires? #34
I had chains on for 8 years on a B7500, yes the blacktop wears the chains a little, but mostly the chains wear the blacktop. It leaves "check" marks on both concrete and asphalt, pretty bad at times. especially when turning.
I tried to stay off the road as much as I could.
James K0UA
   / Has anybody on TBN ever used a B-Kubota w/o loaded tires? #35
Though it is not a Kubota, our 1635 does not have the tires loaded. Never needed tire chains in the winter. If I ever did need rear weight, would either get wheel weights, or just something on the 3 PT.
   / Has anybody on TBN ever used a B-Kubota w/o loaded tires? #36
B2320, 160 hours unloaded. I use a ballast box when needed or leave the chipper on for light loader duties. No problems so far.
Gyro
   / Has anybody on TBN ever used a B-Kubota w/o loaded tires? #37
I have a set of each and I really prefer the way the tractor feels with the loaded tires. I use it a lot on my yard so I have unloaded turfs to avoid ruts. If you are not going to be on grass I would strongly recommend loaded R1s. The thing is unstoppable. Unloaded turfs have zero traction by comparison. I never thought about a flat, I guess I don't read about them enough.
   / Has anybody on TBN ever used a B-Kubota w/o loaded tires? #38
I have a BX-24 in very hilly Vermont (for the last 4 years) and have both R-4 and ag tires loaded. I think (my guess) that it has to do more with the tractor size, meaning the importance of having loaded tires. I nicknamed my Kubota "Flippy" because I feel it has a tendency to want to come unglued on certain hills and certain aspects (haven't "finished" the rollover yet, and would like to not). I usually (but not always) mow with the loader and the backhoe attached, and swing the backhoe uphill in certain spots. I also bought a spacer kit (blanking on the name of the company, but I love it) - spaced the rear wheels out 2" on each side. And you know what? That 2" on each side made about a 50% difference in the feel of my machine on hillsides. Can't recommend it any more highly, especially for a smaller machine like mine. Also, the kit was totally professionally done - all the machinework was tops, and NOW I have studs instead of bolts, so changing the tires (the weighted tires) is not nearly as arduous as it once was when I was doing it with bolts.
The one drawback with the spacers is that I had to have my 54" deck mower's rear idler wheels moved outward several inches, but the local dealership did it for under $100, cut, re-welded, sanded, painted, and did it so cleanly that it's very hard to tell that it didn't come out of the factory that way.
Summary: if you're concerned about your tractor turning turtle due to its small size, I think that weighing the tires is a plus. Haven't found a downside to it yet, personally.
BX-24, 2" rear wheel spacers, non-hydraulic thumb on the backhoe, brush hog, blade, slightly modified 54" deck mower w/gator blades (pretty good blades, too)
   / Has anybody on TBN ever used a B-Kubota w/o loaded tires? #39
Had every other tractor without loaded tires,,,,,,,wouldn't switch back
   / Has anybody on TBN ever used a B-Kubota w/o loaded tires? #40
B2620. Loaded tires with BH and FEL. The dealership told me that they loaded the tires with a beet juice mixture? I live in Vermont and was told this was better than the calcium chloride that has been used and sounds better. Not as corrosive I assume.
BY VALLEY INDUSTRIES 60 R22 823 LOT NUMBER 236 (A53084)
BY VALLEY...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
378832 (A51573)
378832 (A51573)
2014 XL SPECIALIZED TRAILER XL 110 HDG RGN (A52472)
2014 XL...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2007 FONTAINE TRAILER CO. 48X102 SPREAD AXLE STEPDECK (A52472)
2007 FONTAINE...
