k0ua
Epic Contributor
B2620. Loaded tires with BH and FEL. The dealership told me that they loaded the tires with a beet juice mixture? I live in Vermont and was told this was better than the calcium chloride that has been used and sounds better. Not as corrosive I assume.
Calcium Chloride is basically a salt (Sodium Chloride is ordinary salt)
Been there done that, in an older tractor. Its fine as long as it is in a tube and you dont get a leak and the valve stem does not rot out.. but when you get a leak you spray salt water all over the tractor and the grass. Not good.
the Rimguard (beet byproduct) is safe and heavy. I use RV antifreeze. Also food grade safe, but does not weigh as much as rimguard. I could not find a Rimguard dealer so did the RV stuff myself (easy).
James K0UA
