Has anybody on TBN ever used a B-Kubota w/o loaded tires?
   / Has anybody on TBN ever used a B-Kubota w/o loaded tires? #41
B2620. Loaded tires with BH and FEL. The dealership told me that they loaded the tires with a beet juice mixture? I live in Vermont and was told this was better than the calcium chloride that has been used and sounds better. Not as corrosive I assume.
Calcium Chloride is basically a salt (Sodium Chloride is ordinary salt)
Been there done that, in an older tractor. Its fine as long as it is in a tube and you dont get a leak and the valve stem does not rot out.. but when you get a leak you spray salt water all over the tractor and the grass. Not good.
the Rimguard (beet byproduct) is safe and heavy. I use RV antifreeze. Also food grade safe, but does not weigh as much as rimguard. I could not find a Rimguard dealer so did the RV stuff myself (easy).
James K0UA
You guys are great, do appreciate all the insights but nothing beats working it. Grandkids here & when they got tired of playing outside & turned on the TV: voila, opportunity to try FEL + rear blade to start moving some loam/clay to hole I want to fill. 30 minutes later I was impressed w. the B2320 stability but also again pulled out the FEL manual to make sure I wasn't breaking something when loading/scooping & front wheels lifting a bit right before curling up. Getting it figured out a tiny bit & hope I make it to age 90 cuz I love working this little thing.
I like machines and shoulda got one of these when I was 12.
   / Has anybody on TBN ever used a B-Kubota w/o loaded tires? #43
Moving gravel and dirt is kinda like therapy isn't it? I know when I am stressed out, I can go out to the gravel pile and move a little or smooth some out and I feel better. You concentrate on doing the work, and your cares just melt away.:thumbsup:
James K0UA
Therapy for sure. Helped a neighbor today digging/moving some dirt (sand/loam from building project leveled last year) & used rear blade to pull piles then FEL to scoop, travel & dump. B2320 felt very stable w. full bucket--or at least as much as I could scoop--though did learn the saying "you'll run outta traction before HP" to wring true.
   / Has anybody on TBN ever used a B-Kubota w/o loaded tires? #45
I have both loaded and unloaded for my 7610.. Summer treads are turfs "unloaded" Great for light work around the yard but if I push it too hard or use the forks to lift something real heavy I can lift the rears,, My loaded tires are r-4's with chains,, Used in the winter and spring or whenever the backhoe is on,,
2016 JOHN DEERE 8245R LOT NUMBER 182 (A53084)
2016 JOHN DEERE...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
378704 (A51573)
378704 (A51573)
378789 (A51572)
378789 (A51572)
