Repairing metal hydraulic line
   / Repairing metal hydraulic line #1
Pushrod_Paul
Member
WV highlands
John Deere 755 mfwd JD 450B Crawler Dozer
One of the main metal hydraulic lines on my JD755 that run the length of the tractor above the drive shaft has a small hole wore through it (another story).
Instead of having to try and replace the entire line (I'm not even sure I can find a replacement for it) has anyone tried repairing a hole with MarineTex?
I know MarineTex is rated to 2300 PSI shear strength and 8,700 PSI compressive strength, so I'm thinking that may contain the leak.
Any other suggestions on repairing this type of leak without replacing the line?
Thanks in advance.
   / Repairing metal hydraulic line #2
I don't think I would go with the adhesive. I would use a small piece of steel shaped to fit the exterior curvature of the tube and braze (with brass) the patch to the tube. I have done these same kinds of repairs to high pressure lines before and they work well.
   / Repairing metal hydraulic line #4
glue? really? please... that's a problem waiting to happen.. again.. fast..
solder / braze it if it is a thin line.
at worst, I'd UNION it, depending on size and where it was at.
soundguy
Thanks in advance.
   / Repairing metal hydraulic line #5
If you can get the line off have it silver soldered. Same as brazing with a higher quality of material. Brazing will require the metal to be clean and free of oil.
The union idea that Sound Guy sugested would work if the hole is small or you can replace a short section of line.
Dan
   / Repairing metal hydraulic line #6
Is this the small pressure line or the larger return line? Have you checked John Deere for a replacement?
It looks to be about a quarter inch diameter line. There are two of them nearly side by side. The tractor is out at my families farm in West Virginia. We are in the process of putting up a barn when I get out there every other weekend or so. I was hoping to get a repair done on it en-situ until the barn is built and I can afford the time for the tractor to be down.
   / Repairing metal hydraulic line #8
Forget the adhesives just put that out of your mind it isn't going to work that will be a waste of time waiting for it to dry etc and the second you start it will leak.
It needs welded either brazed or mig'd or tig'd to hold any pressure and getting it clean and oil free will be the biggest challenge, get it off the machine is my recommendation but from here that sounds easy hahaha! :thumbsup:
   / Repairing metal hydraulic line #9
I'd forget splicing, because if you have the tools to make the flares, you might as well just make a complete new line.....being 1/4" or whatever it is.
Compression unions won't work on pressure lines, but may work on a return line.
A guy that is good with a TIG could fix it and silver-brazing would work too.
If you have any silver solder, I'd think you could do a 1/4" tube with a propane torch?
I have silver solder, flux and a propane torch. If I clean the outside really well, will brazing it work without removing the line?
2014 Ford E-350 Cargo Van (A50323)
2014 Ford E-350...
John Deere 980 Field Cultivator (A50514)
John Deere 980...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Hyster H225E (A47384)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
2016 CHEETAH 40FT CHASSIS TRAILER (A52141)
2016 CHEETAH 40FT...
