crash325
Elite Member
New Roller build is getting started. Rusty end of tank cut off and some sand shoveled in. Tank that is left, is pretty solid and a full 1/8 inch thick. That is all the sand it going to get. Sand is mostly to scour out the rust and keep the inside clean. When full of water and no air it should not rust any more. Its 36 inches in diameter and will be 4.5 feet long. Have not done the math on gallons of water or weight. Tank by its self over 250 pounds. Yes the Zinc will be ground off where it gets welded.
Old roller will be turned into a Sheep Foot. It痴 a full 3/16 inch thick. It has a thin end that will be cut off, then a new yoke built.
