Dipper Stick snapped in half
   / Dipper Stick snapped in half #31
Yup, except I don't think you even need the come-a-long.
You've got a self contained, rolling frame machine with several powerful hydraulic cylinders capable of a whole range of motions to work with.
It would be a whole different storey if it were in 2 pcs.
You would need some strategically placed chains, and may or may not need a solid anchor, like a big tree
Doesn't matter what it looks like or even if it's not perfectly aligned IMO.
It's an older, probably somewhat loose hoe, no offense Eddie.
JB
The only reason I mentioned the come-a-long is for a more controlled approach. Theres no doubt in my mind that the hoe's own hydraulics are more than capable of doing the job:thumbsup:
   / Dipper Stick snapped in half #32
Like mrmikey said, don't weld straight across the boom, it'll create a stress point and quite likely break there again. The existing gussets are moon-shaped for that reason, any line that goes directly across the boom is bad news. You'll have to get creative with the shape of the reinforcing plates to avoid that.
Discuss that with the welding shop before they start. There's a good chance they already know it, but it won't hurt to talk it over first.
Good luck!
Sean
   / Dipper Stick snapped in half #33
Eddie said he was close enough to drive it to the shop. Couldn't he just chain it it good, so it doesn't break completely off, and just drive it on over?
I mean, like put it it transport position, and chain/strap it.
   / Dipper Stick snapped in half #34
This has shocked me and left me sick to my stomache. I'm physicaly ill over it, and not wanting to deal with it.
I just hope what we've told you has this part behind you. You're going to have it back in action before long.
   / Dipper Stick snapped in half #35
.... any line that goes directly across the boom is bad news. You'll have to get creative with the shape of the reinforcing plates to avoid that.
Good luck!
You are absolutely right. I have seen a BIG Cat excavator boom that suffered a similar failure and was repaired with shaped plates that left no straight line across. However. I would not leave a job like this at a shop where I have to tell them that.
Best of luck with the repair Eddie!!! It will be good as new and your dad will be able to pound away for another 2000 hours at least.
If you can drive it to the near by shop why not just stabilize it the way it is, even if you have to tack some plate to it. The shop can cut it off and line it up properly.
   / Dipper Stick snapped in half #36
Here are the pictures.
I'm nervous about the boom. I've looked for cracks, and haven't seen any, but realize that doesn't mean anything. Once I get the dipper stick off, I'll clean up the boom and look a lot closer.
My dad will dig all day long, day after day, and get a ton accomplished. Unfortunately, he doesn't realize that droping the bucket down onto the ground and then digging by curling the bucket and lifting the backhoe's rear tires off of the ground will eventually cause some damage. I knew that something was going to happen, but honestly thought it was going to be excessive wear of the pins.
This has shocked me and left me sick to my stomache. I'm physicaly ill over it, and not wanting to deal with it. Of course, that's just what I will do until I get it apart and loaded into the back of my truck.
Welding and adding plates to it seems like the best option. If I can find a used one, there's no telling what shape it's in, or what it will cost to get it here.
My plan is to get the bucket off, then build a cradle out of wood to hold it up while taking out the main pin off of the boom. It's going to be one of those days of doing one thing at a time, and then on to the next until it's done. I'll take some pictures and update as I can.
Eddie
call alexander tractor salvage in winsbro they should have a used one they only deal in ford/nh equipment i wouldn't want to weld it
   / Dipper Stick snapped in half #37
Eddie, I might have an inexpensive solution for you. There's a rental yard in Decatur that has two dippers off a LB75 and LB95. He says they are both the same. They both have very minor dents and he got them replaced with insurance. The LB95 dipper looks new. He's asking $450 each, but I was thinking of offering him $750 for both. I didn't do it yet because I had no place to store them until I get my shop built. I have no idea if they will fit your tractor, but I've put a couple of photos of my LB75B's dipper below. If you look at the close-up, you can see where mine has been welded once. I wanted one of the dippers for a backup, but if you want one, I'd split whatever the guy wants for the pair with you. You just need to know if it will fit your tractor. From the photos, your dipper sure looks similar to mine.
   / Dipper Stick snapped in half #38
Eddie, I like Jim's idea if they are a close enough fit. 2nd, around here, there are plenty of welders who have their own truck rigs. Now that its cooler, working out in the open is not a big problem. I don't think its really that big a deal. If you have some scraps and a torch, you might can help the welder cut and fit some side plates and a bottom plate to shore up the crack welds.
Could save a bunch of time and extra work to fix it in place.
   / Dipper Stick snapped in half #40
Quite a few years ago, my father owned a business, Buckets and Booms, Inc., that specialized in building and repairing large buckets, crane booms, etc. That would have been an easy fix. They would have removed the bucket, cut the remaining metal, and pulled the dipper stick. It could be fixed in the field but the realignment would be easy on a concrete floor. Weld it up, fish plate it, paint it and re-install.
If I remember correctly, Eddie has another piece of equipment he could use to lift the dipperstick. The removal and re-install is a pretty straightforward do-it-yourself project.
Any competent welder can weld the pieces back together and reinforce the area. If he's not familiar with equipment booms, it might be wise to help him with the shape of the reinforcing plates so the welds don't go straight across the stick. Copy the shape of the existing plate.
Certainly no reason to be terribly upset. Things break sometimes... I wish my Dad could break something of mine right now. I miss him a lot even after 15 years.
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
JLG 1255 Telehandler (A56438)
JLG 1255...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2014 Dodge Charger Passenger Car (A59231)
2014 Dodge Charger...
2019 Chevrolet AWD Equinox SUV (A59231)
2019 Chevrolet AWD...
