Is this 25-gal sprayer decent at $150? Suggest a weed killer?
   / Is this 25-gal sprayer decent at $150? Suggest a weed killer? #32
Thanks for the replies bepp & clem, appreciate it! Will keep this in mind. Do you think a 25gal would suffice for ~4 acres, spraying for broadleaf weeds that I keep cut at 3.5"?? I don't mind do a refill during the process, but I don't want to constantly be running back to refill the tank...
I've got a lot of native bermuda on the lot, and would like to see it thrive by cleaning out the goose grass, plantain, etc. And 4 acres is too much to cover with a pump sprayer... :p
Using my fine spray rough estimites i think you can spray about 1 tank per acre. You will have to fill up bout 4 X. But depending upon the rates of the 2 4 D or whatever you use that amout of spay per acre can vary. The think you need to consider is the GPM of the pump and the swath width when you want to calculate your ground speed you need to go. It may be so slow depending upon pump output at a fine spray that it makes it painfully slow with say a 4ft boom.
   / Is this 25-gal sprayer decent at $150? Suggest a weed killer? #33
This seems like a huge liability that i will not risk this time of year. We just got the first real rain this week that we have had in id say 2 months! No way im torching anything, esp around a field.
If you set a fire adn burn your house or the neighbors down homeowners may not pay due to u burning weeds. Of course im sure you would not do this when so dry but how do you kill your weeds?
   / Is this 25-gal sprayer decent at $150? Suggest a weed killer? #34
The heat from the torch and the flame
explode the cellular structure of the
vegetation as described on the
weed burning page.
   / Is this 25-gal sprayer decent at $150? Suggest a weed killer? #35
OK clemsonfor, I think I'm beginning to understand... May need to keep an eye peeled for a 50gal with an 6-8' boom, whether it be carryall or TPH mounted. Yes, 2-4-D was what I'm thinking of using, or something similar. Do you use a foam additive to mark your trail?? Been thinking that the first couple of times that might be worth the money spent until I get a feel for the sprayer...
   / Is this 25-gal sprayer decent at $150? Suggest a weed killer? #36
If you had a thing like the bug boys use on one side of a foam trial you can follow that but i think you will need a seperate attachment to make the foam trail. I would just buy a quart of dye at TSC or wherever and Dye the herbicide. Pretty much everything is capatible with dye. The label will say if it is. Most is blue in color and a little bit goes a long way. In 20 gallons you only need a few ounces to make it so dark you cant see through it. Something to keep in mind is that i know glyphosates say that the dye can lessen the effectiveness of the herbicide. I dye about half the time and really have not had it not work though, but i usally mix it to the strong side so that i can spray the grass as well as woddy stems, like sweetgum and other stuff,
   / Is this 25-gal sprayer decent at $150? Suggest a weed killer? #37
Again, good info, appreciate it! I did some Googling (is that a real word??) and it looks like the next size up is a 60gal. I'll be keeping an eye peeled this winter to Craig's List, etc, need several things... Sprayer, grader blade, box blade... Will also hit some of the local farm auctions too. Don't mind buying used blades, but will probably buy a new sprayer, that way I don't have worry about clogged nozzles, crap in the tank, marginal plumbing, etc. Lot's to gather up as a new tractor owner...
On another note, big ballgame for you guys tonight! :) Lot's of people wondering if Clemson is for real or not, or whether last week Auburn was just that bad?? FSU will be tough, would like to see you guys pull this out! :thumbsup: Luck Buddy!
   / Is this 25-gal sprayer decent at $150? Suggest a weed killer? #38
On another note, big ballgame for you guys tonight! :) Lot's of people wondering if Clemson is for real or not, or whether last week Auburn was just that bad?? FSU will be tough, would like to see you guys pull this out! :thumbsup: Luck Buddy![/QUOTE]
Don't miss today's big game ...The Georgia Bulldogs whipping Ole Miss...big time...LOL - Go Dawgs.!:thumbsup:
   / Is this 25-gal sprayer decent at $150? Suggest a weed killer? #39
I have that 25 gal sprayer and I use it on my kudzu....its worked well so far. I use the generic glysophate everyone else has talked about and it does a number on the 'zu. :)
   / Is this 25-gal sprayer decent at $150? Suggest a weed killer? #40
:laughing: Love your location in your profile, that put a smile on my face this mornin'... Up in N Abalama myself!
10' CONTAINER (A51248)
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
Massey Ferguson 1734E, 4wd, Hydrostatic Tractor (A52384)
Massey Ferguson...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
JLG 1930ES ELECTRIC SCISSOR MAN LIFT (A51246)
JLG 1930ES...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
