tractor broken
   / tractor broken #11
Hi and welcome to TBN!
Please post some pics as you progress if you can. Us 2310 owners would like to know! BTW, how many hours on yours? What year is it?
   / tractor broken #12
No problems, no leaks, as I said did not replace any bearings/ seals, did flush out the axle after disassembly, no significant metal shavings.
600+ hrs to date(GC2300)
   / tractor broken
I pulled the pinion SAt. It is toast. I am wondering if the axle shaft and diff. assy. can be removed without dropping the housing. There were no big nuggets in the fluid, just a small amount of fine shavings. When I pull the axle I should see more. The pinion gear did not look like it was sheared off, just pushed aside and flattened. Tried to post pics but no luck.
   / tractor broken
Yes, I saw amkfken's pic of the shaft. Mine is a twin.
   / tractor broken #16
m j w ---you might try puling a picture of my pinion and taking it to your dealer along with yours. Ask why yours shouldn't qualify for a free replacement as the M-F rep that authorized mine also admitted that it was a common problem on the GC's and some 1500 series due to soft steel gears at a certain time period!!
Never hurts to ask, doesn't cost the dealer anything!
Don't know the cost of the gear, probably more than $19.95--but wait--etc. etc.etc.
Good luck!
   / tractor broken
Thanks amkfken. I got everything out and contacted the dealer. The parts are ordered. 10 days to 2 wks. He said he did not know anything about M F replacing those parts but would check. They have a revision on the part #'s , so that tells me that M F is aware. The pinion shaft is $149.20 & the ring gear is $101.72. The bearings all seem o.k. after flushing. I did not drop the MMM or FEL so that made disassembly a lot more trouble than necessary. Live and learn they say. Will post what I find out.
   / tractor broken #18
The very least they should do is replace the known defective parts.
Make sure you mention you have a large audience on the internet awaiting their decision. :thumbsup:
   / tractor broken #19
When I worked parts there was a lot of revisions. They were very, very few parts that were revised that had any problem. It was like they had some desk jockeys that needed something to do to look busy so they changed the suffix.
   / tractor broken
amkfken--Question? Did you disassemble the final drive case and outer wheel housing, or just flush?
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
2007 Chevrolet Silverado 1500 Single Cab Pickup Truck (A55973)
2007 Chevrolet...
2009 Honda odyssey (A55788)
2009 Honda odyssey...
