tractor broken
   / tractor broken #11
Hi and welcome to TBN!
Please post some pics as you progress if you can. Us 2310 owners would like to know! BTW, how many hours on yours? What year is it?
   / tractor broken #12
No problems, no leaks, as I said did not replace any bearings/ seals, did flush out the axle after disassembly, no significant metal shavings.
600+ hrs to date(GC2300)
   / tractor broken
I pulled the pinion SAt. It is toast. I am wondering if the axle shaft and diff. assy. can be removed without dropping the housing. There were no big nuggets in the fluid, just a small amount of fine shavings. When I pull the axle I should see more. The pinion gear did not look like it was sheared off, just pushed aside and flattened. Tried to post pics but no luck.
   / tractor broken
Yes, I saw amkfken's pic of the shaft. Mine is a twin.
   / tractor broken #16
m j w ---you might try puling a picture of my pinion and taking it to your dealer along with yours. Ask why yours shouldn't qualify for a free replacement as the M-F rep that authorized mine also admitted that it was a common problem on the GC's and some 1500 series due to soft steel gears at a certain time period!!
Never hurts to ask, doesn't cost the dealer anything!
Don't know the cost of the gear, probably more than $19.95--but wait--etc. etc.etc.
Good luck!
   / tractor broken
Thanks amkfken. I got everything out and contacted the dealer. The parts are ordered. 10 days to 2 wks. He said he did not know anything about M F replacing those parts but would check. They have a revision on the part #'s , so that tells me that M F is aware. The pinion shaft is $149.20 & the ring gear is $101.72. The bearings all seem o.k. after flushing. I did not drop the MMM or FEL so that made disassembly a lot more trouble than necessary. Live and learn they say. Will post what I find out.
   / tractor broken #18
The very least they should do is replace the known defective parts.
Make sure you mention you have a large audience on the internet awaiting their decision. :thumbsup:
   / tractor broken #19
When I worked parts there was a lot of revisions. They were very, very few parts that were revised that had any problem. It was like they had some desk jockeys that needed something to do to look busy so they changed the suffix.
   / tractor broken
amkfken--Question? Did you disassemble the final drive case and outer wheel housing, or just flush?
TEST YOUR BID BUTTON! (A52709)
TEST YOUR BID...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2019 Ford F-750 Reel Loader Flatbed Truck (A56858)
2019 Ford F-750...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56435)
2023 Kubota Z412KW...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
