Bedder/hiller fabrication
   / Bedder/hiller fabrication #1
Rob-D
Catskills
John Deere 3320
Has anyone built their own bedder/ hiller for making furrows in their food plots?
I'm working on a design and am trying to locate a source for the discs and disc assemblies.
Rob
   / Bedder/hiller fabrication #2
I would like this info too.
   / Bedder/hiller fabrication #4
Just curious what you are planting in your food plots that requires furrows?
   / Bedder/hiller fabrication #5
I'm just gonna buy a old 4/8 row from the cotton/tater farmers arround here and torch it into a 2 row save cut of pieces for parts
   / Bedder/hiller fabrication #6
http://www.tractorbynet.com/forums/build-yourself/200795-my-low-buck-potato-hiller.html
This is my link to a potato hiller I built and it is what you are looking for. It is an old 2" Ford square toolbar with a shank off a MF harrow as a digger and clamps off the Ford to hold the disc hillers. Typical parts are everywhere.
The Ford toolbar was off a cultivator that will acept the round shank of the disc hillers I bought from Agri-Supply. The big curled MF shank clamps to the toolbar. I just put on the biggest V shovel I could find. That's all.
Now, for fall use I take the stuff off and clamp a few of the curled MF shanks to it with smaller shovels. Depending on spacing it leaves neat hilled rows that hold the ground and, if done again in the Spring, I have planted on and it did well. Water in the trench, plant high and dry.
I have a few more photos if you need them and will be setting it up soon to make some furrows to hold a construction site unfinished lawn for winter.
   / Bedder/hiller fabrication #7
Agri-Supply is where I got the discs. Made this simple hiller. Works pretty good, as long as the ground is worked. Will hill up about a foot, and leaves 2 furrows on either side of the hill. In the dry summer, I flood the furrows to irrigate the rows. Mark
   / Bedder/hiller fabrication #9
Rob
Rob,
Below I have a link for what I have done. I designed and buikt it from the stuff I had. buddy of mine gave me two old disk without hub and I did the rest. i ended up beefing it up after where it attaches to the horizontal draw bar. I intend to use it after I till my garden spot nice and fluffy with my tiller and the hipper to make raised bed and furrow on top.
JC,
http://www.tractorbynet.com/forums/build-yourself/210659-my-home-made-row-hipper.html
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2016 Dodge Ram 3500 Stahl Enclosed Service Truck (A52377)
2016 Dodge Ram...
Plasmarc PM150 Plasma Cutter (A54811)
Plasmarc PM150...
2011 DOOSAN G40 GENERATOR (A53843)
2011 DOOSAN G40...
Deer Gates (A53424)
Deer Gates (A53424)
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
