Mowing BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade?
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade?
FYI
-------- Original Message --------
Subject: FW: Oregon Gator Mulcher blade for Kubota RCK54-23BX mowing deck?
Date: Wed, 22 Sep 2010 12:42:20 -0500
To: TBN user wrooster
From: Dennis Wainwright // Dennis.Wainwright at oregonoep.com
We do not currently build a Gator Mulcher blade for this deck.
Dennis Wainwright
Manager, OEP Technical Service
Oregon Outdoor Equipment Parts
Kansas City MO
Phone 800-743-3150 Ext 307
-----Original Message-----
Sent: Friday, September 17, 2010 10:38 AM
To: KAN Techservices
Subject: Oregon Gator Mulcher blade for Kubota RCK54-23BX mowing deck?
Hi,
I have a 2010 Kubota BX1860 with a RCK54-23BX mid-mount mowing deck. This is the same deck used with other Kubota BX series tractors as well, including the BX2360, BX2660, and BX25.
I am looking for a Gator Mulcher blade for this deck. I have not been able to find one that matches on your site, and a search via Google shows others having the same problem.
The blade on this deck is an 18 5/8" long with either a 7/8" [0.875"] or a 29/32" [0.906"] center hole diameter.
In order to use Gator Mulcher blades on this deck, many folks have had to either drill out the center hole in a non-compatible, smaller diameter center hole blade, or make bushings from a Cat1/Cat2 adapter to fit a larger diameter hole blade.
See also:
http://www.tractorbynet.com/forums/kubota-owning-operating/173853-bx1860-54-mmm-rck54-23bx.html
and
http://www.tractorbynet.com/forums/kubota-owning-operating/171351-bx1860-54-deck-gator-blades.html
What Gator Mulcher blade fits on the RCK54-23BX deck?
Thanks for any help.
Regards,
TBN user wrooster
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #12
Has anyone found a different or newer Gator P/N that works stock without having to modify the deck?
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #14
I just wrote to Oregon Tech and got this back.
Could you please give me the Oregon blade number for a
Kubota RCK54-23BX mower deck? Thank you.
The part number would be 396-812. This is a new addition to our offering and will not be available until later this month.
Thanks,
Dennis Wainwright
Kansas City MO
Cell 816-591-3304
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #15
Wonder if they will follow that with one for the 60" deck
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #16
Thanks,
Dennis Wainwright
Kansas City MO
Cell 816-591-3304
Wow! Wonders never cease. Better late than never. Thanks for the good news.
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #17
why does anyone want these non-oem blades?
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #18
I'd like to hear the answer to that question also. What is special about Gator blades, and how much do they cost?
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #19
They are a mulcher blade. I tried them for the first time last week and find that, you don't have heavy rows of cut grass after mowing. It must cut them up smaller and they fall into the grass. They are a much heavier blade then orginal blades.
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #20
I know they are a muclhing blade but I read many comments about them being poor. Many brands same blade.
I would love to see a cut pix using them since I still would use OEM over them anyday.
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
2004 JOHNSTON STREET SWEEPER (A52577)
2004 JOHNSTON...
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
