Unbalanced electrical load
   / Unbalanced electrical load #41
Problem solved. It DOES measure BOTH legs and the balance doesnt change anything.
This photo is courtsey of a fellow member on here, I cant take the credit:
It looks like the two legs go into the current transformer in opposite directions. This way they add the two currents together since the currents are out of phase with each other. Simple and cheap.
   / Unbalanced electrical load #42
Hey Hr3, thanks, i like to refresh my memory , and this is a good site. Just look at the interest in this thread.
   / Unbalanced electrical load #43
I said 1500 watts not 2000.. That is a number you came up with...
I know. I was just using your "theory", NOT the actual #'s you used.
You seem to be thinking the same as me. You pay for what you use. Nothing more, nothing less.
I was just giving an example to compair to daveomak's theory.
Let me try again.
They way you and I understand it, IF there is a 1000w load on leg 1 and a 500w load on leg 2, we are paying for 1500w correct???
The way daveomack thinks, is that it takes the higher load of 1000w, and "assumes" that leg 2 is the same and bills for 2000w.
Now if we balance leg 2 by adding 500w to it...1000w on leg 1 AND 1000w on leg 2, we would now be paying for 2000w correct?
And in daveomak's theory, adding that 500w to leg 2 wouldnt increase what the meter sees, because it already though leg 2 was @ 1000w.
See what I am saying? I wasnt using your "exact" numbers. Rather your theory of understanding. Which seems to be the same as mine:thumbsup:
   / Unbalanced electrical load #44
BINGO. And no difference what the 120v load balance is either
   / Unbalanced electrical load #45
All I know is I'm goin' home right now to move some wires around in my main disconnect panel so I can start savin' for retirement!!! :thumbsup: :cool2:
   / Unbalanced electrical load #46
Let us know how that works out for ya:D
   / Unbalanced electrical load #47
Now we see the light,,:drink: I see why grsthegreat stayed out of this one.. I should have know better..:laughing:
   / Unbalanced electrical load #48
My new status of "independently wealthy" is definitely right around the corner!!
My meter's wheel used to take 60 seconds per revolution - Now it's down to only one minute!!! :thumbsup:
I'm gonna need some investment advice.
   / Unbalanced electrical load #50
Another fact about the new digital meters is they can measure and keep track of any power you send back into the system. The wheel meters will just spin backwards.
Krone Easy Cut TC500 CU (A53317)
Krone Easy Cut...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A57192)
2016 WITZCO RG-35...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
