3pt woodsplitter vs Gasoline powered
   / 3pt woodsplitter vs Gasoline powered #51
Another example. This one is $750. Again, WHY??? A NEW 22T SPEECO is only $999 and a darn fine splitter in comparison???
   / 3pt woodsplitter vs Gasoline powered #52
My Vote is for the 3pt unit, but I have limited storage space and don't want to maintain another engine... Gas with ethanol will go bad sitting in the tank of an engine in 3 or 4 weeks... Even with stabilizers you get phase separation.... so you have to run everything you use out of fuel everytime you use it.... So the last hing I want is another small engine to deal with.... Everything the guys are saying about giving up the use of the machine is true... it is a trade off.
The machine is running just above idle... I'm willing to trade speed to lower noise...
VID 20111015 00002 - YouTube
You can see the cycle time in this by watching the video time.... It will get a bit faster at higher throttle levels....
VID-20111012-00000.3GP - YouTube
Regards,
Chris
   / 3pt woodsplitter vs Gasoline powered #53
yup, my 3 point stands up on the vertical and takes up about 3 SF of space. My 30x60 barn is getting too full, maybe i should stand up all the stuff to take less space.
   / 3pt woodsplitter vs Gasoline powered #54
LD1 - the worst thing besides the price of $1,150 is the engine and the pump are right by your ear when operating - one loud session. These ears don't need that, even with hearing protection. Overpriced, underdesigned. Might split well, I suppose.
Jim
   / 3pt woodsplitter vs Gasoline powered #55
Jim
I am sure it does split wood just fine. It is the sticker shock I cant get over.
What does it take to have the nerve to cobble something together in the garage and demand a premium price for??
And I am not saying anything about his workmanship. I cobble pleanty of stuff together that probabally isnt designed as well as a MFG'ed unit. But it does what I want. But I am ceraintally smart enough not to as a price that is higher than a quality unit.
And the part that always gets me is some of them that they always advertise as "heavy duty" or "built better than a store bought unit". Who are they kidding. Most of them that I have seen are inferior in strength and just cluttered together without any real engineering behind it:confused2:
   / 3pt woodsplitter vs Gasoline powered #56
Tell me about it. I looked for a used splitter for a reasonable price for some time until I gave up and bought new.
   / 3pt woodsplitter vs Gasoline powered #57
Probabally a good choice on your part:D
   / 3pt woodsplitter vs Gasoline powered #58
This is mine before I added the catch table and piped the exhaust to a motorcycle muffler. I've since replaced the cylinder with a new one. The old one started leaking and the shop said it wasn't worth rebuilding. It's a converted 3ph splitter. You can see I used the top link fork for a throttle/choke mount.
105824d1249690035-dsc00009-jpg
   / 3pt woodsplitter vs Gasoline powered #59
I prefer a 3-pt for my use. Don't need an extra engine to keep up. Not worried about speed, I work by myself. Usually stacking as I split, straight off the trailer.
I built my splitter for the JD 520 that I had for years, using the tractor controls. When I sold the 520 & bought a 790, I had to add a control valve & long hoses to use the bucket cylinder connections on the 790. I run the tractor at around 1500 rpms. Bythe time I stack the splits, the cylinder is back up. Works for me! ~~ grnspot
   / 3pt woodsplitter vs Gasoline powered #60
Uuumm this may seem a little too obvious but, if you don't have a separate log splitter, what is the wife supposed to do when you are out running around on the tractor?
John Deere 73 Inch Materials Bucket - Needs Carrier (A55218)
John Deere 73 Inch...
UNUSED JMR 40" HYD ROCK GRAPPLE (A54757)
UNUSED JMR 40" HYD...
JMR MINI TRAILER MOVER ATTACHMENT (A55787)
JMR MINI TRAILER...
2012 Ford Escape Limited SUV (A55758)
2012 Ford Escape...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
2014 Ford Transit Connect Cargo Van (A55852)
2014 Ford Transit...
