Some days you just have to improvise!
   / Some days you just have to improvise! #11
OK, you have hooks on your bucket. What the heck do you need the insert and ball for? I moved my camper and ATV trailer just using a chain from each side of the bucket. It was interesting because I didn't have any ballast in my tires yet. :) But I pulled and pushed both of them several times w/ nothing but a chain.
   / Some days you just have to improvise! #12
I have a little gizmo that i made for mine. I added double 3/8" plate to the top of bucket for the 2-5/16 ball for my goosenecks and an offset hitch for my bumper pull trailers. I made the offset cause im real lazy and didnt want to have to get out of the cab to hook up the trailers. This works slick.....only had to drill one 3/4" hole in lower bucket. It pins on and off in 10 seconds.
   / Some days you just have to improvise! #13
Well, I have various sizes of receiver hitches and I can use them to push trailers around. I also have a 4.5 foot 2X2X1/4 inch square tube boom that comes in handy. It pins in and has a hook on the end that is good for plucking loads from tight spots and moving them.
   / Some days you just have to improvise! #14
I just keep 2" ball on my tractor that way I can move either trailer around without changing balls. I wouldn't go on the road that way but around the yard/farm it's fine.
   / Some days you just have to improvise! #15
That's pretty slick!
I don't have any pics of the bucket hitches handy, but they are just welded to the back of the top of the buckets. I'll get you a view a little later.
On edit: I got shots of the bucket hitches.
OK, now I see how you've done it... Thanks!
Uhh... Yeah, really slick! I gotta get me a torch and welder... :thumbsup: Now, where is my Santa list??? :D
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
JOHN DEERE 4450 TRACTOR (A59823)
JOHN DEERE 4450...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Butler MFG Water Tanker (A56438)
Butler MFG Water...
