Kubota MX5100 Turbo ( opinions needed)
   / Kubota MX5100 Turbo ( opinions needed) #1
joulian
Member
I am trying to determine whats the advantage of a turbocharged tractor ( which I have never owned ) vs naturally aspirated.
I have an L2500 now
I am selling and trying to move up to something I can possibly put a backhoe on ( btw whats the average cost of a backhoe for a 5100?). IS the 5100 capable of handling a backhoe? without breaking it in half.
Anyone got a 5100 that can give some pros and cons.
I have a 16ft gooseneck now any issues with hauling on that trailer ( 10k total axles ). Do i need a bigger trailer etc....
What should I look for if am looking at a 5100 new and used....
   / Kubota MX5100 Turbo ( opinions needed) #2
ive got the mx5100 an i wouldnt have any other tractor.ive had mine for a year an havent had an issue with the turbo.but honestly im used to the turbos on the tractors.an yes it will handle a backhoe no probs.that frame is stouter than you think.your gooseneck might be a tad short if it has the backhoe on id go to a 24ft.i seen a used mx5100 2wd the other day for $15,000 it was a 2008 i think an a gear.
Whats the advantage to the turbo? I would assume the hydraulics function almst at max without turbo kicking in? Unless ur bushhogging or moving something is it worth the xtra.
   / Kubota MX5100 Turbo ( opinions needed) #4
the new gear mx5100s are priced at $19,000 to $26,000 depending on how they are set up.
I need 4x4 for my landscaping bizness
   / Kubota MX5100 Turbo ( opinions needed) #6
the turbo is a real lifesaver when your working the tractor.because once it kicks in youd be amazed at the power it has.i have the mx5100 hst 4x4 w/la844 quicktatch loader.an we was pulling the hay trailer with 4 5 by 6 bales an 1 on the loader.an had it in 4wd drive an it pulled great.was backing in on uneven ground an the tractor just pushed the trailer back no prob.
   / Kubota MX5100 Turbo ( opinions needed) #7
heres how my tractor is speced.its a mx5100 hst 4x4 w/la844 quicktach loader.list price in 2010 was $26,000,an i got it for $24,000.it would help you greatly landscaping.an you can pull a 3pt 6ft tiller with it to till up yards an gardens.
So its 51hp plus turbo added X amount. Which might be what 56hp?
   / Kubota MX5100 Turbo ( opinions needed) #9
its a 52hp tractor depending on who you talk to.an they say the turbo adds 4hp.
Ur replies r a big help! I was actually thinking of not getting kubota bucket on and get the quik attach 2. I want a 4 in 1 bucket. They have em at everythingattchments.com.
Toro Workman Cart (A50322)
Toro Workman Cart...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
2015 CATERPILLAR 573C FELLER BUNCHER (A51242)
2015 CATERPILLAR...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
