different kinda of grapple
   / different kinda of grapple #11
Sorry, I just zoomed in on your pics and see that you did. Again, Real nice!
   / different kinda of grapple #12
It's a very impressive build... :thumbsup:
(darn I hate people like this... I feel so unmanly :p - I'm sure I just need more tools? :D plasma cutter for one :licking:)
THANKS for all the compliments!! I will get some more pics, I needed 3 hydraulic circuits, 1 for the clam, 1 for the swing, and 1 for the front grapple. which I want to be able to use for piling pulp. My tractor only has 2 rear remotes so I had too put in a selector valve, so with the pull of the valve I can switch from the swing circuit to the front grapple. I also put in a couple of needle valves to slow things down a bit. I will shoot some pics of the hyd. tommorrow and post.
   / different kinda of grapple #14
Well it looks like your talented enough to (next winter) make a hyd. tank out of that boom and add a pto pump with a 3 valve bank that you could reach from the seat to run the whole rear grapple and (soon) winch!
   / different kinda of grapple #15
That's gorgeous! :thumbsup:
Thanks
Interesting idea, but after some quick and rough calculations it would hold less than 10 so might not be worth it.
   / different kinda of grapple #17
Heres a few pics of a log skidder type grapple I recently finished. I have some red pine plantations that need to be thinned this winter and hope to make good use of it. Fire away with questions or comments. I did a few preliminary pulls with it before painting, but dont have any good pics, Ill try to get some action pics if I think of it.
Great job Looks Like factory built
I have been gathering info on and off this year ,on building a smaller version of the grapples I see on the internet.. I actually met with my welder friend yesterday. This is insperation. I will have somthing to show before spring. Mine will be much smaller though. Just for say 16 inch butt and down is all i need. Do you know how many pounds of pressure you have on the log grapple cylinder?
   / different kinda of grapple #18
That looks great, very impressive! What is the thickness of the steel used? Can you please add some photos of your grapple? Thanks, Stanley
   / different kinda of grapple #20
Very impressive!!!!!!
I'm looking forward for some pics of it in action. Do you have any steering problems or need for more weight up front? How about a video on youtube?
Thanks for sharing,
Eddie
Kubota Snow plow with subframe
Kubota Snow plow...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A60429)
2018 CATERPILLAR...
19010 (A55851)
19010 (A55851)
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
