Honda Foreman 450 fuel leak
   / Honda Foreman 450 fuel leak #31
Cool, the first I have ever seen. I see NOW! It does put the issue to rest about non adjustability though. I have torn apart many carbs and that is a first for me. Have you replaced the float and needle? Did it come with the rebuild kit? Looked up on a site and for $55 you could replace the needle and float.
$66 gets you the new petcock valve and screen.
http://www.hondaatvforums.net/forums/repair-maintenance/7139-air-cut-off-valve-whats-do.html
http://www.ronayers.com/Fiche/TypeI...odel/TRX450ES/GroupID/317987/Group/CARBURETOR
#27 at the top left corner. Also $63.
Yes...got a rebuild kit from the dealer and it came with new gaskets, float needle and float...$38 and the thing still leaks....grumble grumble.
   / Honda Foreman 450 fuel leak #35
I know this post is old but I have a Foreman just like your with the exact problem and have tried everything you had listed and it still leaks. Did you ever get it resolved?
Just sent you a PM...it details my solution of pressing a tiny thin O-ring into the carb body...I just did that last month...that seems to work but it is trial and error getting the proper thickness. I wish Honda would simply have made the float adjustable.
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
90007 (A51694)
90007 (A51694)
2021 Bobcat S740 (A50123)
2021 Bobcat S740...
