Honda Foreman 450 fuel leak
   / Honda Foreman 450 fuel leak #31
Cool, the first I have ever seen. I see NOW! It does put the issue to rest about non adjustability though. I have torn apart many carbs and that is a first for me. Have you replaced the float and needle? Did it come with the rebuild kit? Looked up on a site and for $55 you could replace the needle and float.
$66 gets you the new petcock valve and screen.
http://www.hondaatvforums.net/forums/repair-maintenance/7139-air-cut-off-valve-whats-do.html
http://www.ronayers.com/Fiche/TypeI...odel/TRX450ES/GroupID/317987/Group/CARBURETOR
#27 at the top left corner. Also $63.
Yes...got a rebuild kit from the dealer and it came with new gaskets, float needle and float...$38 and the thing still leaks....grumble grumble.
   / Honda Foreman 450 fuel leak #35
I know this post is old but I have a Foreman just like your with the exact problem and have tried everything you had listed and it still leaks. Did you ever get it resolved?
Just sent you a PM...it details my solution of pressing a tiny thin O-ring into the carb body...I just did that last month...that seems to work but it is trial and error getting the proper thickness. I wish Honda would simply have made the float adjustable.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2018 DRAGON 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 130...
PREDATOR VACUUM PUMP (A53843)
PREDATOR VACUUM...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
