Diesel exhaust fluid
/ Diesel exhaust fluid #41
Taking away a option even as small as a heated WWF unit sets a president.
Chris
Shure there is an underlining issue of not fixing the problem and just removing the "feature"
my issue is, if they cant seem to fix a heater for something simple like WWF... what are the odds they can successfully design multipul heaters to keep the DEF from freezing and f'n everything up.
/ Diesel exhaust fluid #42
Personally I've never seen the need for heated washer fluid, and probably I'm not alone..That's probably why they sent checks to the owners after that option didn't pan out...Never heard of AC or radios being recalled and disconnected. That one wouldn't stand for any manufacturer.
As far as power seats, I set mine when I bought it 9 months ago and haven't touched the controls since...Same goes for the pedal adjustments.
I say this living in a cold winter part of the country, I'd actually like to see someone invent heated wiper blades instead.
Just jousting with you Chris...All in good fun.
I see your side of it also. I am opposite. 3 different people drove one of my trucks last weekend alone so all my adjustments get used quite often.
What I am saying is legally GM got away with murder on this WWF heater recall. It set up the whole industry, not just GM, to take the cheap route. I guess I am too RED NECK but there is no way I would stand for a fix like that or lack of. I would have caused such a stink they would have wanted to buy the truck back. Its not so much about losing a little option, its what they could do down the road.
I know this is extreme but what if they had a problem with a cool option on your new truck, something like the brake controller. Instead of fixing it they decide to just deactivate it and give you $100 to get a P3? Now you have the factory one in the dash that does not work and a P3 under doing the work. Part of the reason I bought my Superduties was Ford was the only one with a built in brake controller back in 05. I would flip out if they did not support it along with the rest of the truck.
I just feel us as Americans as a whole have gotten soft. We do not stand up for whats right. I buy something I want it to work. If not the manufacture needs to figure out how to make it work as advertized. By letting them slip by the cheap way and getting off easy sets up the rest of the industry for the same practices.:mad:
Chris
/ Diesel exhaust fluid #43
Chris
Chris, while I enjoy your writings, your anti GM stance does get old. I will give you an example of your what your beloved Ford pulled on my father. Now granted this was back in 1978, but I just want to show you what Ford DID with something FAR more serious than a WWH.
My father bought a brand new Ford station wagon in 1978. With about 2500 miles on it, he left it idling in park, got out and walked over to put some items in his truck. Next thing you know the car goes into reverse and smashes into his truck. He calls Ford and lo and behold there is in fact a problem. Want to know how your beloved Ford handled it? They sent him this awful gawdy sticker to put on the dash that read: "Do not leave car idle in park. Use neutral and apply the emergency brake." That was their answer, never did fix the tranny. He sold it that way. At least they did pony up for the damages done, BUT they NEVER fixed the problem.
/ Diesel exhaust fluid #44
You know little about me so dont make assumptions. I have owned more GM products than I have any other brand including Ford. While I do think there is no comparison to Ford when it comes to trucks that is where my loyalty stops.
If I had that situation and it was not resolved as in your fathers case I would have taken my sticker with me to the dealers and ran it though the front of the building. Don't believe me, you have not met me. I would have then gotten out of the car with the sticker in my hand and said I was coming in to have the service dept help me install it when the car did it again.;) Prove me wrong.
Call me Red Neck or whatever you want but I don't take any crap from anyone and always get even. I would call that even.:D
I have a feeling that what happened with the Toyotas was as much my way of dealing with a issue as it was a problem with the cars themselves.
By the way, I will not own another GM for one reason only, the bailout. Nothing to do with quality, ect. I am done with them.
Chris
/ Diesel exhaust fluid #45
Chris
I'm sure an accountant somewhere said it would be cheaper to give everyone $100 bucks than fix this. That should worry people. What if it was cruise control and they figured it would be cheaper to give people $250 than fix it but it was an option that you used on a regular basis? What if you use the heated WWF to deice your windshield in the middle of winter. The trick of wrapping a hose around a radiator pipe is worthless if your engine is cold.
/ Diesel exhaust fluid #46
Chris
Chris - I am not assuming anything. Your anti GM posts here are well documented, and your love of Ford is also well documented. I am not meaning in any manor to start something, that is just the way it is.
It is very easy to say you would drive your vehicle through the showroom, but something tells me you are smarter than that. Because you know in the long run you would pay dearly for it, probably land in jail over it, and in the end it would accomplish nothing.
I hear you on the redneck thing, but again you seem like a sharp guy and I am sure you know there are times when the good guy just does not win.
Regards
Storm
/ Diesel exhaust fluid #47
pure urea (the majority of the exhaust fluid) has a melting point of ~273 F
which means the systems employ a series of heaters to keep the fluid liquid (especially in cold times and in cold climates) (not just a tank heater but a line heater and injector heater)
The majority of it is Deionized water. 67.5%. The other 32.5% is pure industrial grade Urea, not fertilizer grade.
It freezes at 12*.
We have a fair number of Class 8 diesels with DEF in the fleet right now and for kicks and grins we tried 28%, the same stuff we put on Corn. It works just fine.
You must have one of the earlier trucks that a certain MFG didnt program the sensors properly and you could even run water in them. But maybe you dont I dont know.
Now you cant do that(maybe you can), the sensors will detect if it is not pure DEF.
DEF has a shelf life of 4 months-2 years. The deciding factor is heat. Over 86* and it will start to degrade. So make sure you only buy what you need and store it out of sunlight and in a cool place if possible.
Interesting. I Learn something new everyday. Things just tend to get more complicated. I wonder if they're do the same for tractors...
Yes they are, currently have one on the farm with it. All but Deere and Challengers larger tractors with CAT engines, have SCR.
Um have you read the news? GM cant keep the DEF from freezing, they're having glitches left and right. hopefully they got it fixed this time though (update #20). Im a diehard Duramax Fan, but not afraid to admit their issues.
Now on the topic of DEF. The system is called SCR, Selective Catalytic Reduction.
Simply put it is injected into the exhaust at a variable rate to control NOX emissions. When injection it reacts in the catalyst to convert the NOX into water, Nitrogen and a trace amount of CO2.
NOX and particulates are the two to remember when it comes to diesel emissions.
There are currently 2 systems in place for reducing NOX.
EGR/NOX absorbing catalyst. and SCR. Both systems use Particulate filters for the particles but its important to look at how each system affects that pesky gremlin called the DPF.
The EGR based systems rely on creating colder combustion temperatures and recirculating large amounts of EGR. This creates a cooler combustion which results in less NOX. However anybody who payed attention in school knows that cooler combustion is more inefficient. Which holds true, with the cool combustion the particulates do not get burned which causes the DPF to plug up much faster than on an SCR motor. Also due to the cooler more incomplete combustion fuel efficiency suffers. In addition the added particulates in the system cause premature wear and require more frequent oil changes (Example is the 200hr OCI on the John Deere(EGR) versus the 600hr interval on the case IH (SCR)or 400hr interval on the Massey/Challenger(SCR))
The SCR approach relies on aftertreatment of the NOX. meaning they can tune the engine for maximum power, performance and efficiency and let the SCR system scrub up the large amounts of NOX later on. This also results in less particulates which means fewer regens, longer engine life and longer OCIs.
SCR also allows MFGs to use smaller engines to produce the power needed, again this goes back to the heat factor. Case IH is running a 12.9L In their biggest tractor (they used to run 15L) and are making 600ratedhp (SCR) and 670 peak hp. Challenger is using an 18L engine to make 585hp (EGR)
So is SCR new and not proven? NO!! Its been used at power plants and in Europe for a while.
SCR does have its downfalls though. The main one is the DEF itself. Its a pain to handle. Its mildly corrosive, makes a mess, freezes and doesnt last long. There are more solid solutions in the works though to replace it.
/ Diesel exhaust fluid #48
Finally, someone else with there eyes open.:thumbsup:
Chris
/ Diesel exhaust fluid #49
Regards
Storm
Well, if it ever happens maybe you will read about me in the paper.
Chris
/ Diesel exhaust fluid #50
Chris
I think the heated water bottle is being taken to an absurd conclusion here. I'm going to go out on a limb and say that the heated washer fluid wasn't a destination option, just something that was there like many useless options on the truck I currently have.
If it was special ordered, I'd certainly make a stink about it. Cruise control et.al are must have's in many peoples' book...Those wouldn't get the same treatment. In fact, the only time I've ever heard of this washer thing is on TBN...No other public uproar anywhere..This kind of thing usually gets some press.
There's also the possibility that there was no solution due to a sole supplier...I really don't know. Again, I have never even wondered about having that option and I live in the snow belt. Heated wipers would be much more effective.
/ Diesel exhaust fluid #51
Got to agree with Storm. Your Anti-GM stance is well known in this forum.
As far as your disapproval of the bailout that is your business. I think that the bailout was more the result of GM's upper management rather than the company as a whole. If the company had competent leadership it would have not needed a bailout in the first place.
There are quite a few people who feel exactly the opposite about GM trucks vs. Ford. There are legions of 6.0 diesel owners who would gladly trade theirs for a D-Max. Of course, you've never had any problems with yours but the D-Max was a hunk of junk.
I think both companies make great products, but at times let the little things get out of hand as far as quality.
BTW: I drive a Ford 6.0 PSD.
Regards
Storm
/ Diesel exhaust fluid #52
Just some FYI links to those curious about heated washer fluid, doesn't pertain to original topic. Yes, I agree GM could have handled it much better. Original unit was made by the lowest bidder and they went out of business. They should have manned up and replaced them with these.
The most I use it is in the summer actually, takes the bug guts off a lot better.
AlphaTherm Heated Wash AT-37GM is direct replacement for ALL factory installed General Motors “GM” heated washer fluid modules
Comparision between original and replacement:
http://www.alphathermusa.com/files/Comparison_MH35_vs_AT37.pdf
/ Diesel exhaust fluid #53
And to think when working on gas turbines used to pump oil on the north slope pipe line while with GE R&D we could simply inject steam into the exhaust to knock down the NOX.....
Since we can only use urea on the ramp in the winter in front if my hangars, I wonder what it would take to mix my own fluid?
/ Diesel exhaust fluid #54
Ford video about DEF and its use.
[ame=http://www.youtube.com/watch?v=GF5Oggb7gUk]2011 Ford Super Duty Diesel Exhaust Fluid (DEF) Tutorial - YouTube[/ame]
/ Diesel exhaust fluid #55
Folks ranting in every thread. Seems to be a lot of unhappy people. The question is; what are you all going to do about it?
This forum is full of smart people with a lot of passion in what they believe.
I have read 10 random threads on various subjects.
They all degraded to political discussions.
I pray to God, that you all are prepared to act this year and every year going forward.
Details matter, elections matter, standing up for on another, matters.
Do your best in everything you do.
You have a job, give it your all.
You manage people? Treat them right.
Divided we fail.
Mike.
/ Diesel exhaust fluid #56
Oh yeah, DEF is a way to make money and make the diesel less desirable.
That is my 2 cents, for this thread.
/ Diesel exhaust fluid #58
Divided we fail.
Mike.
I think it is because there isn't one area government doesn't stick it's nose in. With diesel yes they should have been cleaned up, but there was corruption and they did it in a way intentional or not that screwed American diesel engine companies, mainly Deere, Cat, and Navistar.
The government should have allowed DEF/SCR 10 years ago. Cat acutally sued in the late 1990's to allow other things to control emisions but lost in court. Instead the EPA mandated EGR only till 2006-2007. Then late in the game changed the rules so DEF was OK. Too me this gave a huge advantage to anyone with European ties due to they were allowed to use DEF over there. Everyone who has a overseas partner is using DEF, the 3 American companies are all going EGR because that is the direction they went world wide. That was why Cat got out of the over the road engine buisness and Navistar is trying to sue the EPA for mandating EGR, then not.
Most of these rules came from CARB (CA Air Resource Board) and the EPA just rubber stamped them. The guy who did the studies was a fruad and all of his work was full of mistakes. This has been known by members of CARB for years yet they said nothing. Many believe it was to set the bar so high as to make diesel must less affordable and not about health.
This is just one story about the CARB fraud.
http://www.landlinemag.com/todays_news/Daily/2009/Dec09/113009/120309-02.htm
With crap like this going on, is it a wonder people aren't mad?
/ Diesel exhaust fluid #59
Sounds like Hien T. Tran looked at what the CARB people wanted and then made up "facts" to suit their desires. You can be quite sure that if his findings contradicted their desires that they would have instantly abandoned both Tran and his report as soon as they found out about his faked doctorate degree.
The CARB group reminds me a lot of the AGW crowd for some reason...
/ Diesel exhaust fluid #60
I think you are right. There is even a web site that wants to end CARB, don't know who is behind it, but they do have some interesting information. CARB has even tried dropping the C to change the name to ARB some think because of this fraud has given them such a bad name.
KILLCARB.ORG -
Another point about Cat, Deere and Navistar. They are some of the few compainies that have been bringing jobs to America instead of shipping them overseas over the last 10-15 years.
Deere has brought a CUT and Skidsteer production here among other things. Cat has brought in some engines that were made overseas and this year expanded in the midwest a plant. Cat also build a combine factory in partnership with Claas, closer to 15 years ago. Navistar bought the Cat over the road engine plant and is keeping the factory running. They could have sourced a overseas engine for there trucks.
Figures governments makes it harder on the hometown guys yet looks the other way when Chinese companies break the rules and infringe on patents and what not.
As far as AGW, isn't that what they do also? Come up with the theory, then come up with studies by hook or by crook that show what they want.
2016 Deere 180G (A60462)
2016 Deere 180G...
2016 Ford F-150 Pickup Truck (A59230)
2016 Ford F-150...
40' 6 Door Shipping Container (A60352)
40' 6 Door...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
2013 Club Car 4x4 Diesel Utility Cart (A59228)
2013 Club Car 4x4...
