Darn, this thread is going on so long that I need to check my L5740 HSTC. The dealer said the remote flow and pressure is checked on all the machines they sell after installing the remotes and before customer delivery so I never questioned it. I have charts on different size simple reliefs and they all increase from cracking pressure to full flow, but surely Kubota would have selected a size that would have protected their 3,000 rated pump at full flow. Unfortunately my pressure gauges have 1/4 pipe and the QD couplers have 1/2 pipe and it is an 80 mile round trip to a store that sells hydraulic fittings or I would have numbers from mine at various engine speeds tomorrow. I will get numbers on mine as soon as I can.
Looked high and low and can't find a spare port anywhere. Teeing into a steel line is a little above my pay grade.:laughing:
Unfortunately and quite frequently their are no pressure taps on valves an yes teeing into a steel line without extra hose and fittings is a real challenge.
A possible solution to getting readings at both the FEL valve and the rear remote. I believe you have two gauges correct?
If yes and your valves allow you to "Feather' we (this means you Kubo) can possibly simulate having a gauge in the pressure port.
Install the gauge like you have been in your loader circuit. If you have the second gauge and can see them both install it in the rear remote.
Now comes the fun part. Carefully feather the FEL control until you start to see pressure around 500 - 750 PSI would be good. Now while holding the FEL control in that exact position operate the rear valve. What pressure do you see in the FEL gauge? What pressure do you see in the Rear remote. If this a common circuit the pressures should be very similar.
Best of luck on this Kuboman since some valves allow feathering much better than others. If the loader control don't work possibly try the curl.
Roy
Roy;
Well this just keeps getting more interesting. But this test you suggested I just did.
I installed a pressure gauge in the down circuit of the FEL deadhead.
I installed pressure gauge in rear remote, deadhead.
I feathered the down circuit to the loader and achieved a steady 700psi.
I then engaged the rear remote. I got 700 psi at the rear remote. Now here is the fun part. As I engaged the RR the loader lifted. Yep that is what I said. The loader went up. Disengaged the RR and the loader settled back down.:confused2:
Maybe someone who can read the schematics better than me can explain this.
This is making me a :drool::drool: idiot.
Roy;
