The RR was always higher. As I brought up the curl pressure the RR would fall until they equalized around 24-2500# and then at that point the relief opened and the RR went to 0.
Once again, this does not make sense. Last time I Checked Pascal's Law states "that fluid in confines chamber will have equal pressures in all directions." By closing off the RR you in essence have a contained volume of fluid from the RV to the RR. Pressure in this line should be relatively constant from one end of the line to the other.
Can you hear your Relief valve when it operates? If yes did the sound seem to change when shifting the RR Vs the FEL? Should be none but....
There is no logical explanation that I can think of to explain what you are seeing. Back to our regularly scheduled program of :mur::confused2:
Dang my head hurts..
Well try this again. The loader valve is bypassing the relief valve and the 3000+psi that you are getting is the safety opening. I don't think I would put hi rpm on the tractor because I wouldn't think that valve can handle the full flow of the pump. The 3pt refief well not open until there is more load on it that it can't lift. The feed back well not let the refief open if there is no weight on the 3pt. Have kubota put a new loader valve on. I would also ask the dealer if you could open the old valve up and look inside of it.
That is true and that is why I'm saying there is something not right with the loader valve.
Question I have is, what in the loader valve would create higher pressure down stream? I keep coming up with the conclusion of nothing.
I cannot see how it could be plumbed incorrectly since operating the FEL stops flow to rear remotes.
I am open to any and suggestions on what the problem is.
Roy
