2" receiver on drawbar
   / 2" receiver on drawbar #1
aa777888
JD3520
I am a fairly new tractor owner. I'd like to tow a small utility trailer I have to carry brush, etc. I am able to find no end of 2" receiver units for 3 point hitches, but the attachment that would seem to be a no-brainer, a 2" receiver that either bolts to or replaces the drawbar is not to be found anywhere.
I did see a nice photo of a home-built one on the site. Unfortunately I do not have a welder nor the welding skills. I could have a local fab shop build one for me, but I'm just amazed I can't simply buy one.
Any suggestions?
Tractor in question is a JD3520, if it matters.
Thanks,
aa
   / 2" receiver on drawbar #3
Can't you find a pin with a ball on the top from your tractor supplier. One would think it as a standard thing to buy with a tractor.
Bob--as I wrote in my original post, those are dime a dozen. I would have bought one already if that was what I wanted.
Doppel--never seen one of those. Got a link to one I can buy? I'd still prefer a receiver, though, so that I can put different ball carriers into it.
Thanks,
aa
   / 2" receiver on drawbar #5
So let me ask a dumb question -- why don't you want to attach a ball to the standard drawbar? That's what I have been doing. You could even buy extra drawbars if needed.
   / 2" receiver on drawbar #6
Any suggestions?
Thanks,
aa
I know what you are asking for, but, it doesn't seem to be manufactured anywhere.(I've searched everywhere)
You'll probably need to get one custom made.
   / 2" receiver on drawbar #7
This is where the confusion comes in.
The actual drawbar on a tractor is not the 3pt. hitch, the drawbar is the bar that protrudes from the bottom of the tractor near the rear end........it doesn't move.(well, not up and down anyway)
Some smaller tractors have the drawbar hole molded into the steel that is part of the tractor frame.
That is the 'towing-pulling point' of a tractor.
Edit: this Farmall BN is upside down, but the drawbar is visible.
   / 2" receiver on drawbar #8
What I like about the attachment for the TPH is that you can adjust the height of the ball. Seems like the drawbar is kind of low for most trailers.
   / 2" receiver on drawbar #9
It is kinda low, but if you are using a ball mount, you can get hitches that rise up 1, 2, 4, 6, inches. But I haven't seen one with a receiver.
Towing with the 3pt, can be a challenge.......as the 3 pt. can move up on you while in motion and cause all kinds of headaches. Can possibly cause a flipover if on a downslope, depending on what you a pulling. My logsplitter has given me a good jolt several times here in my yard.
   / 2" receiver on drawbar #10
It is kinda low, but if you are using a ball mount, you can get hitches that rise up 2, 4, 6, inches. But I haven't seen one with a receiver.
Towing with the 3pt, can be a challenge.......as the 3 pt. can move on ya while in motion and cause all kinds of headaches.
The only towing I would do with it would be just to move the trailers around.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
2019 John Deere 1025R 24HP 4WD Loader Utility Tractor (A60460)
2019 John Deere...
2004 GMC Sierra 3500 Utility Flatbed Truck (A60460)
2004 GMC Sierra...
2019 GALYEAN...
