Need to cut off a dead limb about 30' above ground
   / Need to cut off a dead limb about 30' above ground #172
Bep, hey glad all worked out for ya, I know you feel good about your accomplishments this past weekend as you should:thumbsup:, it's been a tough crowd here holding the fort down until you posted:D.
   / Need to cut off a dead limb about 30' above ground #174
:laughing::laughing:
Are you from Florida too?
East there GolfAddict, cause you know one day you aspire to relocate here and drive slow in inside lane with blinker on.:laughing:
   / Need to cut off a dead limb about 30' above ground #175
BTW, sure enjoyed the "fort holding" over the weekend. It's been a hoot!
   / Need to cut off a dead limb about 30' above ground #176
Glad you enjoyed, I sure did take a beatin, but as long as some have released some endorphins, well that's just a bonus
   / Need to cut off a dead limb about 30' above ground #177
aczlan said:
For vertical loads, yes, but a horizontal (ie side load) or a shockload is another story.
Aaron Z
I'll bet it's true with the boom straight out horizontal, and I don't imagine the hydraulics are strong or fast enough to shock load anything beyond design load either; you would have to drop a load on it or something like that. Not that it couldn't have been done, but Billy Joe Bob isn't going to achieve it by hooking to an elephant and trying to lift it off the ground normally.
   / Need to cut off a dead limb about 30' above ground #178
True, it probbaly cant hurt itself lifting something vertically, but if you were lifting a load that was badly rigged and it were to slip, drop 3 feet and catch, you could easily shock load the boom.
Or, try to lift and pull sideways with the boom extended.
Aaron Z
   / Need to cut off a dead limb about 30' above ground #179
Aaron Z
They are beautifully designed machines, but it's designed to be as light as possible, look at how small, almost dainty the components are compared to the heavy duty 4x4 construction grade machines, that do not allow for crane use.
Even though the manufacturer sanctions the use as a crane, You could easily damage one of these tow behinds with negligent material handling use.
The rental industry is notorious for abused equipment. I just don't think it's a great idea to promote them as dual use.
Miniature Construction World - JLG T350 Towed Boom Lift
I've used the 50 footers a few times in the last 2 years, I am impressed with their capability for such a compact portable package. 50 feet is pretty high for such a light duty machine, there's alot of play in them at that height.
JB
Toro 880 Procore (A55758)
Toro 880 Procore...
2011 Toyota Camry (A55758)
2011 Toyota Camry...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A55973)
2019 Freightliner...
Case skid steer wheels and tires (A56435)
Case skid steer...
2016 BOBCAT T550 SKID STEER (A52709)
2016 BOBCAT T550...
LOT: (2) Komatsu Part # 207-70-73210, (2) Komatsu Part # 208-70-73220 (A59076)
LOT: (2) Komatsu...
