Need to cut off a dead limb about 30' above ground
   / Need to cut off a dead limb about 30' above ground #161
I wouldn't worry about prior abuse. Presumably such a unit would be designed such that the hydraulics run out of power to lift way before any physical damage could occur from lifting.
   / Need to cut off a dead limb about 30' above ground #162
For vertical loads, yes, but a horizontal (ie side load) or a shockload is another story.
Aaron Z
JB...I guess you get used to it after a while. I tree climb as well as tower climb. You learn to trust your equipment and then you are not so anxious.
Beppington...I forgot to tell you that I had already dibbs'ed your tractor in the event that something happened...
Seriously...I am glad you got it solved. That what does not kill you makes you stronger...(or something like that from Conan the Barbarian).
Well, it might as well have gone to you - My woman wouldn't know what to do with it :laughing:
   / Need to cut off a dead limb about 30' above ground #164
That which does not kill you, only postpones the inevitable (could have been Steven Wright, but not sure where I got it).
   / Need to cut off a dead limb about 30' above ground #166
That's funny...but true! I did not see that thread on favorite lines till you mentioned it...Some pretty funny stuff...
   / Need to cut off a dead limb about 30' above ground #167
Cut the tree down, then remove the limb.
   / Need to cut off a dead limb about 30' above ground #168
   / Need to cut off a dead limb about 30' above ground #169
That's an idea.
   / Need to cut off a dead limb about 30' above ground #170
That's an idea.:D
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2012 PROCO KILL TRAILER (A58214)
2012 PROCO KILL...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
Miller Millermatic 25 Welder, SKU# 907321, S/N MJ260223N, Rated Output-Amperage 200 (A59076)
Miller Millermatic...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
