This is what my manual says for the HST.
Do not use a oil dual rated as CF. Do use an oil rated either CI-4 or CJ-4 10w-30 or higher.
For the HST you can use basicly any quality universal tractor fluid. I would avoid the cheap stuff and stick to the major manufaturers who all put out a quality product. My local Walmart carries Rotella universal tractor fluid Walmart.com: Rotella Tractor Fluid, 5 Gallon: Automotive
What you will find through some research is that what is referenced in the manual are products that meet a certain spec. Since the manufacturer does not have their own spec in this case you can choose a different manfacturers spec. I typically look for JD J20C. Always look for products with the most current spec listed on its products. For instance J303 is far out of data but still referenced on many fluids.
http://www.epc.shell.com/Docs/GPCDOC_X_cbe_24855_key_140002123012_6BD1.pdf
http://www.pqiamerica.com/THF Reprint.pdf
