Building a Snow Plow :)
/ Building a Snow Plow :)
It is visually impressive, you do nice finish work. My concern is what is to keep the bottom of the plow from being pulled under the mount where the hinges pivot?
Hey Mike, Thank you for the compliment ;)
I took 2 pix closed up so you can see. I'm thinking putting another 2"x4"x24" so it can hit the Bracket when it hit snow. Right now it's only like 1" hitting the Bracket. I tried it by pushing in Front of the Plow and the Tractor moved, it didn't go under at all, but yah, anything can happen right?
One of the Pix is lifted a bit so you can see the different. Maybe you got other Ideas??? I'm all ears...:D:thumbsup:
/ Building a Snow Plow :) #22
On the attached picture I added a red section. I would put a piece of wood there attached to the metal bracket so the plow rests against it when down. Shape it so it matches the angle. The bottom part of the plow will get loaded up, without something for the pressure to be dispersed to I think your wood will fail at the bottom.
Hi Mike,
Yes, that is the Location where I was going to put the 2x4x24. You read my mind, thank you!
Did you get any snow few days ago? I didn't get much, just dust then wet, then rain.
What town are you in NH may i ask?
thankx for the input again!:D
/ Building a Snow Plow :) #24
:thumbsup: Interesting build. Snow might want to stick to the wood. Just a thought. If you can get a 55 gal plastic syrup barrel and cut it lengthwise and use that as the blade. would be lighter than the wood, and snow wouldn't be as likely to stick.
You didn't look in the front :(
:confused2:
/ Building a Snow Plow :) #26
Hi Mike,
We got a bit of snow, just enough to look nice in the trees. Man was it cold this weekend though. I live near Nashua, I try not to give too much detail in such a public place. ;)
:D LOL. Yah, it's COLD still LOL
Oh, pretty close then. Hmmmmm, what are you affraid of? Even if you tell them the Town, how the **** they gonna find you. I live in Haverhill, MA try to find me, LMAO
Even if anyone try to find me, what are they gonna get? If I don't like them, they might get a good old shoe up their *** LMAO. :D:cool2:
/ Building a Snow Plow :) #28
Ha ha. I try to limit what I put on the web, I have a family to watch out for. My 2 dogs are good at watching out for them too, scare the crap out of the delivery people. :D
/ Building a Snow Plow :) #29
I am impressed. That looks great I just hope that it holds up for you, but either way it was just time. On a side note with being i.deed; I think it is a good thing to remain obscure until you build some kind of relationship with an individual and that is subjective. With that said photos may end up being your Achilles heel. because I recognize that tractor, lol. Especially that custom snow plow; now all I have to do is find it. Great job and thanks for sharing- I wish I was that talented.
Awe, thanks Zork ;)
" I wish I was that talented "
LOL, I don't think it's Talent, I think it's Dedications... Hmmm, maybe I am and I don't know it, LOL.
Although I do have Talent in other department, like Poker... What if I tell you that I found a Formular for Poker? Oh, trust me, you will know me when the Book come out ;) I will make sure to Blow up a picture of my Custom Plow so people will recognized who I am when they come for my Book Signing . LOL
Anyway, here is an update Photos for the Plow after 1 usage!
I def needed a Metal Blade and Snow Shoes, which I never got a chance to do it. Although the Garden Fiber Divider / Garden Edge thingy can't really hold up that good, LOL. Well it's FREE after all so I can't really complain and I have 4 more of those so I'm gofnna use them until they are gone then go buy a peice of Metal for the Blade. The Winch was helpful because lifting was easy and a snap.
Everything else was AOK with about 45 Mins. of usage. Things holding up pretty good, especially I had to Plow the side walk it's like 1 Path of about 48" X 200' long.
/ Building a Snow Plow :) #31
This build brings back teenage episodes for me.
Way back then I kinda hooked a plow made from plywood and scraps of hardwood with bedspring angles as cutting edge that I hung off of my early VW beetle bumper.
My 'lift' mechanism was a hockey stick firmly attached with bolts and a cord that I pulled for lifting from the open driver's window.
As crude as it was, it worked very well on loose powdery snow.In the heavier wet snow it simply tore apart, but it was all fun.
In those days the neighbors paid $1.00/hr for us to shovel the drives.
That was when snow shovels were made from wood!
hehehehehe,
I'm glad I was able to bring you back on your Memory Lane :thumbsup:
It was definitely for FUN, what else am I gonna do with bunch of FREE good Pine Boards and Botls, Screws....
If I had to pay for it, I would have gotten Metals and Weld a good Plow. But then again, why bother go through all that while I can go to CL and get one for $100 Bucks.
But it's FUN though to go back to your Memory Lane i'm sure;) Wish someone take me back to those days :):D
Although I must say, that's pretty inventive of you using your surrounding to your advantage. Your Teenage Brain must be working full-time back then :thumbsup:
LOL
/ Building a Snow Plow :) #33
rgs03833
Very interesting build and thread. I like your ingenuity.
I have one suggestion. Replace the side boards with braces on the back of the plow, like those on truck plows. This would probably add strength and let the snow roll off the sides easier.
The idea would be to cut some plywood sections to match the profile of the blade. Double or triple each brace. Put one on each end and maybe on or two more in the middle.
Here's a drawing of showing braces cut out of plywood. Something to consider anyway.
rgs03833
Well here is the Update.
I decided to get a Snowthrower since I found on CL for $180
In the process of getting it together as you can see. The Ground / Driveway is NOT flat and the Sidewalk kinda that way too, so I went and purchase the Thrower instead. Now what am I gonna do with the Snow Blade? LOL
/ Building a Snow Plow :) #35
Put it in the house of fame. It's too cool to junk it. Maybe give it to a neighbor.
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
2003 Big Tex 10PI...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
UNUSED KJ K1522 HEAVY DUTY PORTABLE RESTROOM (A60432)
UNUSED KJ K1522...
2013 CHEVROLET SILVERADO EXT CAB TRUCK (A60430)
2013 CHEVROLET...
30ft Highway Trailer Co. Lowboy (A61306)
30ft Highway...
