rigid flood lamps, anyone like em !
   / rigid flood lamps, anyone like em ! #21
It will be a while before light fixture manufacturers use ISO standards for rating their output. The LED flashlight manufacturers started about 1-2 years ago. Before the standards I think they all measured them about as close to the emitter as they could. Now they are at a standard distance.
...so if you assume that everyone making these LED utility lights is doing what the flashlight manufacturers were doing - trying to get the highest output adding possible, you may not have an absolute output number but you should at least be able to quantify the relative differences between them.
   / rigid flood lamps, anyone like em ! #22
yup, they need an industry wide standard. I know that Metal Halides put out 100 lumens per watt, so a 400 watt MH outputs 40,000 lumens. For an LED to come colse...its a ways off in the future still
I should have them and installed mid next week, so will see if there bright.
   / rigid flood lamps, anyone like em ! #24
Let us know...if they're good and project a lot of light...might be a good source.
However, if you're dissatisfied with their output, let us know too, please...
As I'd written, I haven't seen good light out of LEDs....not for worklights, at least. Maybe these are different...
Most certainly will. They will be returned if I am not happy, as a matter of fact I was told by a ridged industries that if I don't think there the best lights I have ever owned I can return them without question.
   / rigid flood lamps, anyone like em ! #26
These two pics are with the factory headlights then two work lights that are rated at only 1100 lumens - just 1.1 amps each. Compared to the factory headlights, I think they are reasonably bright for $40 each. They would not have enough "reach" for a car going 60 mph but at my average speed, they are plenty fine. For reference, the third reflective marker on the left would be about 130 feet away.
   / rigid flood lamps, anyone like em ! #27
I have a set of the flood duallys for the back of my truck for plowing, they work great, you will not be disappointed. I was so happy I ordered another set which will go on the back of the tractor for night work. I am also thinking about the d2's spot for the front of the truck.
Great :thumbsup: Thank you for your comment, I was second guessing my decision about the purchase. But other people on forums also say they are very good. :D
   / rigid flood lamps, anyone like em ! #29
work light are up higher so always project further. Get a pic of the headlights without the bucket in the way blocking the light for a fair comparison
id like to see. Its actual comparisons that help us all decide. thank you
There is a pigtail under the operator's seat for that work light I mentioned. This energizes when the lamp switch is turned to the appropriate position. That might be a good place to run your wiring.
Found it, thanks Roy.
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
2019 CATERPILLAR 262D3 SKID STEER (A52705)
2019 CATERPILLAR...
