Bulldozer and 3/4 ton truck
   / Bulldozer and 3/4 ton truck #71
Hi guys, new to the site but thought I would post as I was in a similar situation as the OP.
I looked at many skid steers, 4x4 tractors, dingos, etc.. demo`ed many & when it came down to a purchase I bought the Magna Trac struck crawler 4800 used with attachments.
Ill say this, I was skeptical until I ran it & then I was convinced, I have made back a good part of my purchase & that was within 6 months, I needed a niche machine that could do the ugly stuff & the struck fit the bill, I have moved uprooted trees, dug out foundations (rocky soil), spread gravel, plowed snow, etc..
The only problem I had was the one track would jump off....easy fix & for $80.00, havent had any other issues....you would not regret the purchase, yes it is expensive!! but its built very well, american made & will do more than you think...........you WILL make your money back if that is your intention! easily moved with a pickup!! IMO better than a bobcat/skidsteer..easily!!!
LXT
   / Bulldozer and 3/4 ton truck #72
Hi guys, new to the site but thought I would post as I was in a similar situation as the OP....
Since you are new... BTW, Welcome to TBN... :welcome: there's a rule that you must post photos of your Magna Trac :D . . . (ok, it's not an official rule... more like my rule :p)
   / Bulldozer and 3/4 ton truck #73
teg,
I hear ya & I will see what I can do about posting some pics, really dont have any but I will take some & put em on!
I always think about pics, but once I get to the job or work around the house I just go..... nice site here & am hopeful I can learn alot! thanks for the welcome!
LXT
   / Bulldozer and 3/4 ton truck #74
There is a really nice old D8 for sale near us for 6500$, it would be a monster and clean up a lot of stuff, but it could be such a money pit. Instead I went out and bought a really heavy 8 ft 6 way hydraulic rear blade. I can pretend to do some dozer work that way!
   / Bulldozer and 3/4 ton truck #75
I have been looking at bulldozers for 6 months off and on and really need something 30-40 hp that weighs less than 10k pounds (trailer capacity is 12,500k). I want to be able to move it with my diesel powered F250. I found one @ northern tool for 15k, 30hp and weighs a little under 7k lbs. It sounds ideal and most of the reviews are positive. I will be clearing underbrush and after my property gets a thin cut, cleaning up some left behind trees about 12" in diameter, nothing real heavy. I need to be able to get in some tight spots and can't have anything too big. i looked at a Case 1150C, but it weighed 29k lbs and will probably leave too big a footprint. Any thoughts???
I pulled a D-3 with 3/4ton chevy"gas motor".
I own a D-31p pulls easy with my 1ton diesel,nice little Dozer picked it up for $6500
   / Bulldozer and 3/4 ton truck #76
I just got a Komatsu D20p6, it pulls great behind my 3/4 ton Dura/Allison with a deckover bumper pull trailer. It's amazing to me what even a little dozer can do.
   / Bulldozer and 3/4 ton truck #77
I agree even a small dozer will do alot, it will take more time but depends on what ones situation is?
I figure this, when the machine breaks or gives ya problems & it will!!!!!! you will no doubt be in some god forsaken hole that no other non-crawler machine will even be able to get to, my Magnatrac weighs under 4000lbs so if it craps out on me I should be able to atleast drag it outta the hole?
I had a JD 440, old machine but nice...well when the output shaft broke I was in a hole & at over 6000lbs thats not an easy pull, local farmer had to pull me out & to work on that thing..........wow! 2 men & a boy with tools for a D-9, with the struck a 1/2inch, 3/4 or 9/16 does just about all!!!
LXT
   / Bulldozer and 3/4 ton truck #78
LXT
Be very carefull thinking this way it may cause you to find even more equipment in a hole. :laughing: Just because the machine only weighs 4000lbs does not mean puling it out of muck and suction type clay will only be 4000lbs.
   / Bulldozer and 3/4 ton truck #79
LOL, true but I dont usually take equipment in to the hole that shouldnt be there & gettin a 4000lb machine out is much easier than a larger one!
I know just the difference in messing with tracks is night & day between the 2 machines & with only a 2000lb difference........Ill change tracks on the struck any day over a JD 440 or 450.........I guess the key is dont break down? :laughing: boy if that was only possible?
LXT......
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
UNUSED X-STAR 20' X 101" LOADING RAMP (A51247)
UNUSED X-STAR 20'...
2010 JOHN DEERE 4730 LOT IDENTIFIER 239 (A53084)
2010 JOHN DEERE...
(5) 55 GALLON POLY DRUMS (A51248)
(5) 55 GALLON POLY...
SCAN FOR HAULING AND FINANCING INFORMATION (A51246)
SCAN FOR HAULING...
LOT LOCATIONS (A53426)
