CK35H Fuel tank collapsed
   / CK35H Fuel tank collapsed #21
I think I would be hesitant to try air pressure ... to much could blow the tank and in this case how much is too much?
   / CK35H Fuel tank collapsed #22
Seriously, is the reduced capacity an actual problem? If it isn't leaking and you can live with the reduced capacity, why not just wait until summer and see if it fixes itself? After, of course getting a vented filler cap.
Thanks to all for the ideas and suggestions. This forum is very helpful.
I am happy that my local Kioti dealer is working to get me a new tank under some warranty. My guess - purely a guess - is that Kioti has had some trouble with malfunctioning fuel caps. I'll keep you posted.
   / CK35H Fuel tank collapsed #24
Good news. Hope it works out. Even better if they put it in for you.
If they don't put it in, I'll be looking for manual pages to show me how.
   / CK35H Fuel tank collapsed #26
Thanks WhiskeyWizard. What dangers are there in re-inflating? If I replace the tank, I will need help in how to do it. The shop manual does not give much of a clue.
Over-inflation can cause a rupture. And the escaping gas is gasoline vapour. Very flammable. You would need to drain and purge before attempting it. Or do as suggested earlier where you fill, then gently warm in the sun.
EDIT: I see you're on the trail of a new tank. That's much better!
:) The dealer not only replaced the defective cap but also replaced the collapsed fuel tank. Way to go Kioti dealer!! Thanks for all the support on thius thread.
Forklift (A59228)
Forklift (A59228)
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
Polaris Ranger (A56859)
Polaris Ranger...
2022 John Deere Z930M (A57148)
2022 John Deere...
