P tires to LT tires on an 07 ford expedition el?
   / P tires to LT tires on an 07 ford expedition el? #1
zlock24
New Martinsville, WV
jd 445, kubota bx1500,wheel horse c-160, wheel horse h-520
So I'm wonder if you can go from passenger tires to light truck tires using the same rims? Or would it be like trying to put R1 s on R4 rims? Haha
   / P tires to LT tires on an 07 ford expedition el? #2
Do not know for sure but I do this all the time with home made car trailers etc. The handling may change with something with steering and suspension under it. I do have a hay rake with p series and whitewalls.
   / P tires to LT tires on an 07 ford expedition el? #4
No problem. The letter designation signifies the load rating more than anything else. P tires are "passenger" with a 4 or 6 ply rating. LT tires (light truck) are 6, 8 or 10 ply rated.
Stiffer sidewalls, more capacity, but possibly harsher ride. P rated tires are used to give a better ride on a truck. LT tires have a higher min. and max. inflation rate. If a nice ride is important, you may lose some of it. It's not wise to run LT tires at the lower inflation weights of P tires. I did have a customer than put P tires on his 3/4 ton truck because they were cheaper. His low tire pressure light now stays on all the time. He can't safely inflate the P tires to enough pressure to put the light out. If you use LT tires you shouldn't have the tire pressure light problem. But you run the risk of having underinflated LT tires without knowing it.
   / P tires to LT tires on an 07 ford expedition el? #5
No problems as long as you stay around the same size.
Chris
   / P tires to LT tires on an 07 ford expedition el? #6
You also need to check the weight ratings on the P tires to make sure they can handle the weight of the expedition - its certainly not a lightweight vehicle.. IIRC- when you use a P tire on a 'truck' type vehicle you loose some of their rated weight capacity..
Any particular reason you want to go with a P tire?
Brian
   / P tires to LT tires on an 07 ford expedition el? #7
here is what I found on TireRack.com regarding the use of P tires on heavier trucks/suvs - it looks like you loose ~10% of the P tires rated capacity when used this way
You certainly dont want to cut any safety corners by going with a P tire.. If you go to tirerack and put in your tire size it will list both P and LT tires - then in the specs it lists the weight capacity and speed ratings..
Tire Tech Information - Load Reduction of Euro- and P-Metric Tires on Light Trucks
Brian
   / P tires to LT tires on an 07 ford expedition el? #8
Brian
The OP is swapping the OTHER WAY!
   / P tires to LT tires on an 07 ford expedition el? #9
   / P tires to LT tires on an 07 ford expedition el? #10
There is no problem but it won't give you more GVWR in regards to the DOT. Also a problem I ran in to once, just doing it the other way around (going from LT to P) is that if you have TPMS (pressure sensors mounted inside the tire), then your TPMS lamp will always stay on. I've tried reprogramming the tire pressure module with no success. I went to the dealer, and even the technicien was unable to modify it in the PCM. The pressure difference was to big, going from 80 psi. down to 35 psi. So I just covered the lamp in the dashboard with a piece of tape.
But maybe your lucky and don't have this annoing option.
Hope this helps !
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
AFF 8888 CANTILEVER WASTE OIL DRAIN (A51248)
AFF 8888...
2020 JOHN DEERE 5125R LOT NUMBER 120 (A53084)
2020 JOHN DEERE...
American LaFrance Thermoplastic Striping Truck (A52377)
American LaFrance...
(APPROX 20) 3" X 4" X 21 7/8" TUBING (A51247)
(APPROX 20) 3" X...
2019 FREIGHTLINER M2 26' BOX TRUCK (A51247)
2019 FREIGHTLINER...
