Rancher Ed
- Joined
- Apr 22, 2011
- Messages
- 294
- Location
- Texas
- Tractor
- 2008 Kubota M7040 4WD w/loader, 1979? Mitsubishi D2600 4WD w/loader
Fit wise, as long as they are the same size or close you will be fine. One thing to check though is the max pressure the rims are rated for. I don't know if this is a problem, but as you get to a little bigger tire there are a few sizes that some have a max of 80psi and others in the same size just a higher load range have a max of 120psi, and some rims are only rated to 80psi so you have to check if the want the higher rated tires.
I think you are being smart switching to the LT tires, given the size of your rig (almost the same size as a suburban), especially if you ever tow anything with it. Even just loading it with everyone's stuff for a road trip, you could be close to the rating on the P tires.
Ed
Ed
