check your lug nuts + torque wrench madness
   / check your lug nuts + torque wrench madness #21
Where would the average Joe be able to get his torque wrench calibrated? I have pretty much done all the things thatI'm not supposed to do with mine.
- I usually leave it set at 110 ft-lbs from torquing my wheels.
- It has bounced around inthe my truck tool box for 5 yrs or so.
- I have removed tight lugs with it (in leiu of the proper breaker bar).
Considering those things I bet its way outa whack.
   / check your lug nuts + torque wrench madness #22
Its not worth it to be honest. Wait till HF has them on sale and get a new one with a case for $9.99 with the coupon. I know 10 or so guys with them and they are accurate enough for most purposes. I believe they are accurate to plus or minus 6% or something like that.
Chris
   / check your lug nuts + torque wrench madness #23
All lug nuts should be retorqued after a brief run regardless of whether or not they were done at predelivery. You would be hard pressed to find an operator's manual or tire shop invoice that didn't say so in plain English.
Yes, and that applies to any vehicle, anytime a wheel is taken off and reinstalled or replaced. Rust and dirt on the drum/wheel surface, temperature, paint on the wheels can all allow the lugs to loosen slightly. If you are on the road and really in a bind time wise, simply stopping every couple hours and putting the cross wrench on each lug nut will tell you if anything is moving.
   / check your lug nuts + torque wrench madness #24
You could look locally for calibration businesses, thru yellow pages or a google search. I have searched while looking for Cal services that our in-house lab does not offer(I work at a large electronics comapny; we have an in-house Cal lab that does probably 75% of internal calibration; some stuff has to go out for various reasons).
It may cost more than a $9 cheapo import as Chris mentions though....
Quality on the cheapo import tools varies widely though; I would be suspicious, even if an occasional sample is good...
   / check your lug nuts + torque wrench madness #25
If I were maintaining my million dollar each airplane engines or building high dollar high HP race engines I would also be concerned with quality. For trailer hitches, lug nuts, diff covers, oil pans, tranny pans, ect the HF units are just fine. Heck, even if it were off 5% or even 10%, that is close enough. The key is to get uniform torque.
Chris
   / check your lug nuts + torque wrench madness #26
I can see Chris's point. HF makes it so cheap to get the tool, that it certainly beats out the difficulty of getting your existing wrench calibrated. I'll also not in the business of building rockets, so a wrench within 10% would probably be acceptable.
   / check your lug nuts + torque wrench madness #27
Depending on your area, it would not be hard to get it calibrated. The issue would likely be price...
At least for me, being close to the greater Sacramento area, it is more about driving there/back, and the actual cost. Of course, it would be similar drive to go to Harbor frieght too.
Edit: I asked the internal Cal Lab here; when they send them out it is about $70
   / check your lug nuts + torque wrench madness #28
doing a quick Google search i found this place right off the bat.
Torque Tool Service, Repair and Calibration Lab - Team Torque Inc.
Looks like $47.50 will get your click type wrench cal'd (up to 250#) with a
4 day turn around. http://www.teamtorque.com/documents/torquepricing.pdf
there are plenty more. i know nothing about the above company, we have our own cal lab where i work staffed by a dozen or so techs who do nothing but cal all our test equipment from torque wrenches to o-scopes and everything in between.
here's another
Transcat Torque Calibration Services | Torque Wrench Repair | Stahlwille Torque Products
Transcat I have used in the past for gauge calibrations, but not torque.
   / check your lug nuts + torque wrench madness #29
i never use a torque wrench and never had for any tire. If i dont hammer lug nuts on with my impact gun, ill put half of my 240 pound weight on each lug with my foot on my wrench.:thumbsup:
   / check your lug nuts + torque wrench madness #30
Now now, remember there ares a fair number of engineering types here, who want to see accurate values to the third digit when using correct torque for loose loader mounting bolts ect... :D
Anything less, and my tractor will fall apart :D First there were ROPS police, next Torque police...
I would though, like to know how my wrench is reading...
Chris
Spreader Attachment (A56859)
Spreader...
159116 (A60430)
159116 (A60430)
1995 John Deere 7400 (A60462)
1995 John Deere...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
Toro Sand Pro (A56859)
