Depending on Demand, We may be going Vertical.
   / Depending on Demand, We may be going Vertical. #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
Basically we are contemplating re-building Wheel Lift Disc Harrows and converting them to Vertical Tillage. Here is where are so far.
* This tillage tool is for the smaller farmer who wants new technology without having to buy a 25 or 30 ft. model and mortgage a farm to pay for it.
* This is a versatile tool which can be used for many operations. (corn stalk shredding, seedbed preparation, manure incorporation, leveling of ruts in the field and more. This type tool is the hottest topic in farm magazines, discussion forums and local farm supply stores. Vertical tillage tools are currently produced by Salford, John Deere, Great Plains, Case IH and many other manufacturers with prices ranging from $30,000 to $90,000.
* This is a used Bush Hog Model 1427 Disc that we converted to a HD Vertical Tillage Tool.
* This tool cuts and distributes crop residue and also destroys small weeds, while warming the soil to a shallow depth and releasing excess moisture to create an ideal seedbed.
* Operates well on higher moisture ground.
* Does not pull up rocks like regular disc harrows do.
* Coulter depth adjustment by hydraulic cylinder and the addition of weight.
* This tool features 30 new 20"diameter, 13 wave coulters.
* 8 HD Bearing assemblies which can be greased.
* Coulter gang angles can be adjusted from basically straight across to more aggressive angles by turning crank at each end.
* Weight drums are included for even deeper tillage. 2-- (55 gal. drums) can add an additional weight of 880 lbs. when filled with water.
* Perfect tool for chopping up corn stalks, etc... in the fall and can go back in the spring for seedbed preparation and destroying of small weeds.
* This tool can also be used for aeration of pasture fields, incorporating fertilizer and preparing fields for seeding.
* Perfect tool for the serious food plot guy!
The Information below was taken from "High Plains/Midwest Ag. Journal"
"Agronomist discusses vertical tillage--what it is and how it works.
There's a new trend in tillage equipment called "vertical tillage" and a Kansas State University scientist says it could also be described as "mulch till."
"The main objective of using vertical tillage is to break up surface soil compaction, or smooth out areas in a field with shallow (2 to 3") rills from water erosion or ruts and tire tracks from tractors, combines, grain carts, trucks, and other equipment," said DeAnn Presley, soil specialist with K-State Research and Extension. "It also is used to help improve rainfall penetration by breaking up crusts."
Vertical tillage equipment is used to lightly till the soil and cut up residue, mixing and anchoring a portion of the residue into the upper few inches of soil while still leaving large quantities of residue on the soil surface. This action helps speed residue decomposition, Presley said. The best description for vertical tillage is to call it a form of mulch-till, as it generally leaves more than 30 percent residue on the soil surface, yet creates nearly full-width disturbance on the soil surface."
More pictures to follow next week. We are going to sell this completed unit for $4495 FOB, Munfordville, Ky 42765. Ken Sweet
   / Depending on Demand, We may be going Vertical. #2
I'll look forward to the rest of the pictures. I've read a couple pages and watched a couple of videos, and so far I can't figure out how those things work.
   / Depending on Demand, We may be going Vertical. #3
I am also looking forward to reviewing additional pictures and info. Thanks for posting.
   / Depending on Demand, We may be going Vertical. #4
So is that a 12' model? How much horsepower will it to to pull?
Finally a small farm tool, now how much to refurb an old combine?
Thanks
Mike
   / Depending on Demand, We may be going Vertical. #5
Good thinking Ken. Those machines are very popular up here in Dakota. We are primarily no till here but the "Salford" and "Summer's Supercoulter" are used as a way to size residue, level sprayer and combine ruts, and incorporate fertilizer. Some guys will run them a day or two ahead of the planter to get a little drying action before they plant.
However we have started to notice that there is a developing hard pan from too much use of these machines. Its starting to look like we may be a bit drier here this year (we've flooded for the last 4 years) so guys are ripping some of the ground to open everything back up and then we'll revert to no till again.
Again, good thinking on the machine. It will work great for size of growers that are on here!
Thanks
Mike
This one is 8 ft. If fully weighted, I am guessing 55-60 HP to pull deep in our clay based soils. Ken Sweet
   / Depending on Demand, We may be going Vertical. #7
Great post ken ... a lot of discussion on vertical tillage all over. I have been planning the same thing with an old disc ... I'm thinking just remove all the concave disc and put in new straight "coulter" disc and adjust the gangs as needed... I will be watching this for updates.
No row crops around me so no corn stalk residue ... so my plans are to subsoil the hay and pasture ground to break the hard pan and then for aeriation the straight coulters.
I'm thinking especially in my area there has been very little concern for the ground moisture, the plant root system, nutrients .... I mean heck its got to help.
Our primary concern is to keep surface moisture from quickly running off during a rain. Our Corn fields are rolling. Incorporating more of the stalk residue into the growing zone, should also help with a better corn root system that can take up nutrients more efficiently. Ken Sweet
   / Depending on Demand, We may be going Vertical. #9
Excatly ... I subsoiled some before our recent 4.3 inches of rain and could see a big difference in the run off. I was amazed at how compacted my soil is.
UPDATE: Here is pictures of the finished refurbed and converted Vertical Tillage Tool for smaller farmers. Ken Sweet
   / Depending on Demand, We may be going Vertical. #11
Do you think with the blades you now have on it that if the angle was changed to be sharp again it would be like a disc? You know where it may serve as both a vertical till and a tandem disc?
I am thinking that 5-10 degrees is about all the angle side load I would want to put on the 20 inch flat/wavy blades. Ken Sweet
   / Depending on Demand, We may be going Vertical. #13
I would think they wouldn't take much angle ... I said earlier I was thinking about converting my disc to this ... I may shop for another and redo that one.
Its definatly an interesting concept.
   / Depending on Demand, We may be going Vertical. #14
Mostly just curious here but, do you think it would even be possible to make a smaller (say 5ft wide) VT and still maintain the proper disk to weight ratio, such that a CUT would be able to pull it and achieve the desired effect? If so, do you have plans to eventually build one along that size??
We are working on that now. Ken Sweet
   / Depending on Demand, We may be going Vertical. #16
I would think no matter the size ... with the proper disc blades and weight you could create this.
Update: Sold our first 8 Ft Vertical Tillage conversion tool to a fellow in North Carolina. Starting on second one currently. Ken Sweet
   / Depending on Demand, We may be going Vertical. #18
Looks great :thumbsup:.
Now you've gone and done it -- you've inspired me to start yet another project--converting my old Minneapolis Moline KS1300 (made by Krause) wheel disc into a VTT :D. Should be relatively easy to do since I cut that 13-ft disc down to about 7.5 ft wide so my 2008 Mahindra 5525 (54 hp engine) can handle it.
View attachment 252185View attachment 252186
Should work fine if you can run the discs straight and be sure to keep the axles a little longer for the thicker 6mm coulter blades. Ken Sweet
   / Depending on Demand, We may be going Vertical. #20
Great Plains is now making one with the disks at a slight angle. It does not work like a usual disk, but it is better at killing weeds. My dad has a 25' (i think) straight blade model an it does not do as well as he had hoped for killing weeds especaily mares tail.
Corn tilled only with it did do quite well though.
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
2022 WEILER S350 SKIDDER (A60429)
2022 WEILER S350...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
S/A Utility Trailer (A59231)
S/A Utility...
