Hand Pump for Deep Well Water aka Human Powered.
   / Hand Pump for Deep Well Water aka Human Powered. #21
If you want real simple put a check valve on the bottom of a piece of pipe and move the pipe up and down. Viola-water pump.:thumbsup:
   / Hand Pump for Deep Well Water aka Human Powered. #24
If/when you decide on a hand powered pump, how you going plumb it ?
Would it not need its own down line ?
If your original down line is anything like mine, ain't no way I could drop a line down along side of the original. Mine has plastic thingys that keep it centered every so feet and another anti spin plastic thing at the bottom.
Now I could pull it, then drop 2 lines down at the same time.
   / Hand Pump for Deep Well Water aka Human Powered. #25
   / Hand Pump for Deep Well Water aka Human Powered. #26
Simple & Cheap.
Just put in a raised storage tank. Depending on a lot on how much water you use, would determine the size.
At one place we had way off the grid we had a 3,000 gallon tank at 14' above ground for inside water and a 1,500 tank near ground level for out side water.
At the mining claims where my sister lives there is a 500 gallon tank at about 15'. Plenty of water pressure at both places. We did have a gas pump on the 1,500 gallon tank.
Deep Well - 30'. Sure does not sound deep to me. Current well is being pumped at 340'. Around here that is not considered deep.
Have you thought of a well bucket? Thousands of people got their water this way in rural area without any electricity. I've drawn many a bucket this way.
How to get water from a drilled well when the power is off by Steve Belanger from the January/February, 1999 issue of Countryside & Small Stock Journal
Yes but my idea of a well bucket did not match what is in the link. :D It seems like a good cheap idea that would be pretty fool proof. The pump design they have is interesting.
Later,
Dan
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
GOODYEAR SET OF 420/85R30 NEW AG TIRES (A52748)
GOODYEAR SET OF...
2014 Ford Escape (A50324)
2014 Ford Escape...
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
