Hand Pump for Deep Well Water aka Human Powered.
   / Hand Pump for Deep Well Water aka Human Powered. #21
If you want real simple put a check valve on the bottom of a piece of pipe and move the pipe up and down. Viola-water pump.:thumbsup:
   / Hand Pump for Deep Well Water aka Human Powered. #24
If/when you decide on a hand powered pump, how you going plumb it ?
Would it not need its own down line ?
If your original down line is anything like mine, ain't no way I could drop a line down along side of the original. Mine has plastic thingys that keep it centered every so feet and another anti spin plastic thing at the bottom.
Now I could pull it, then drop 2 lines down at the same time.
   / Hand Pump for Deep Well Water aka Human Powered. #25
   / Hand Pump for Deep Well Water aka Human Powered. #26
Simple & Cheap.
Just put in a raised storage tank. Depending on a lot on how much water you use, would determine the size.
At one place we had way off the grid we had a 3,000 gallon tank at 14' above ground for inside water and a 1,500 tank near ground level for out side water.
At the mining claims where my sister lives there is a 500 gallon tank at about 15'. Plenty of water pressure at both places. We did have a gas pump on the 1,500 gallon tank.
Deep Well - 30'. Sure does not sound deep to me. Current well is being pumped at 340'. Around here that is not considered deep.
Have you thought of a well bucket? Thousands of people got their water this way in rural area without any electricity. I've drawn many a bucket this way.
How to get water from a drilled well when the power is off by Steve Belanger from the January/February, 1999 issue of Countryside & Small Stock Journal
Yes but my idea of a well bucket did not match what is in the link. :D It seems like a good cheap idea that would be pretty fool proof. The pump design they have is interesting.
Later,
Dan
Garbage Truck (A51692)
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A52472)
2021 ALLMAND BROS...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52748)
2004 Capacity Yard...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2014 BOMAG BW 213 DH-4 (A52472)
2014 BOMAG BW 213...
