What did you do to your tractor today?
   / What did you do to your tractor today? #131
Finally I have brought an engine from the workshop to my farm's garage yesterday using my own rig (distance ~100 miles). The tractor assembly works will start as soon as the weather conditions will become a bit friendly, at least a couple of degrees above 0C (32F). Hope it'll happen after a week or two.
   / What did you do to your tractor today? #132
Today I sent it back to the shop for a full service visit, changeover to a quick attach setup, addition of rear remotes, purchase of a bucket, grapple, and pallet forks to add to the quick attach. I'm also sending along my curtis snow blade to have it converted over, and also add the hydraulics to make it a power angle.
Thanks Rick Wallace for all your help!
Cheers,
Sabooo
   / What did you do to your tractor today? #133
...full service visit, changeover to a quick attach setup, addition of rear remotes, purchase of a bucket, grapple, and pallet forks to add to the quick attach. I'm also sending along my curtis snow blade to have it converted over, and also add the hydraulics to make it a power angle...
Wow, did you hit the lottery? :D Don't forget the "after" photos!!!
I lifted the engine out of my Land Rover with the tractor today:cool:
   / What did you do to your tractor today? #136
I hand dug a ten foot tall `cedar`, and then with the Kubota I lifted it out of the hole, and then hand dug another hole and lowered the tree into it......hard work cutting the roots with the pick ax, and shoveling the dirt :) easy tractor stuff even though I broke a spindle off the railing for the steps....Didn`t make me mad as I did it :) Tony
   / What did you do to your tractor today? #137
What happened with an engine? Age, mileage?
I bought it as 'good' 70thousand miles and running great when taken out motor
Put it in my Land Rover and it would only fire properly on 3 cylinders
It's a 200 tdi (2.5 4 cyl Turbo Diesel)
Took motor out and found a bent conrod on No 4:mad:
Some people tell lies when selling motors, I wouldn't but some do unfortunately
Land Rover 90 ( defender) 1990
   / What did you do to your tractor today? #139
Sad story.
I had such cases with the customers while working in a position of workshop manager. It happens when engine sucks in water inside the cylinder. But usually engine even not starts after that.
In your case I would better fix an original engine or would purchase remanufactured one from certified workshop with the warranty. It's more expensive, but with minimum risk.
Try to get back to a seller and talk to him.
Giyi 59" Vibrating Roller (A53316)
Giyi 59" Vibrating...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A55745)
2018 MACK CHU613...
2010 Komatsu WA320-6 Articulated Wheel Loader (A55787)
2010 Komatsu...
2022 Kobelco SK17SR-6E Mini Excavator (RIDE AND DRIVE) (LIKE NEW) (A50775)
2022 Kobelco...
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
Yale Warehouse Forklift (A53314)
Yale Warehouse...
