Case485Guy
Gold Member
Basically, if you want a used reliable diesel truck made from 2003-2009, go with a Ram or GM and forget about all the Ford diesel horror stories.
Ditto
Dang it, David. Don't you know that, in a good argument, you're not supposed to confuse the issue with the facts? :laughing:I am a Ford guy. I own stock in Ford, I will only buy Ford products. I believe I sad that in the opening of this thread (I am the OP afterall...).
Are you sure it is not a conspiracy?
So I need to add this stuff to my gasser motors too?
And all of you people b!tch about computers and all their arcane needs... HAH!
Thanks for yet another firehose I need to drink from to learn how to be the guy I need to be.
David
Don't worry about the gas-burners, unless you're one of those people that never flush the cooling system and put in new anti-freeze.
It depends on how you use vehicle and your climate.MossflowerWoods said:Guilty as charged...
I'd better go look up the truck's manual, I've put over 50K on it and not flushed it once yet...
I always thought if the color is right (i.e. no rust) no probs!
David
I was talking about never. For example, last year, I bought a little '97 Toyota 4x4. I recently had to replace the radiator. (plastic top tank cracked) Talking about nasty coolant. The truck's odometer is showing over 250K miles, and I don't know if the cooling system had ever been flushed and refilled.Guilty as charged...
Soundguy or Diamond Pilot, or ???
Was there a 2000-2002 F-450 SRW crew cab 4x4???
I just saw one on a lot and I was VERY CURIOUS...
Please advise.
David
PS - Never mind I just found the dealer on the web and their ad states F-250 with F-450 badging... Liars...
why put the 450 badging on it?
why make it hard to figure out. reminds me of the plain old 'superduty' badging...
My truck is technically a 250 but, I have x and c code leaf springs. The c codes are off of a 350 DRW.
You make a good point. Does DOT allow you to reclassify yout GVW due to improved springs?
My problem is they state no upgrades to the GVW, but they rebadged it as an F450?
WTH???
David
