What did you do to your tractor today?
   / What did you do to your tractor today? #131
Finally I have brought an engine from the workshop to my farm's garage yesterday using my own rig (distance ~100 miles). The tractor assembly works will start as soon as the weather conditions will become a bit friendly, at least a couple of degrees above 0C (32F). Hope it'll happen after a week or two.
   / What did you do to your tractor today? #132
Today I sent it back to the shop for a full service visit, changeover to a quick attach setup, addition of rear remotes, purchase of a bucket, grapple, and pallet forks to add to the quick attach. I'm also sending along my curtis snow blade to have it converted over, and also add the hydraulics to make it a power angle.
Thanks Rick Wallace for all your help!
Cheers,
Sabooo
   / What did you do to your tractor today? #133
...full service visit, changeover to a quick attach setup, addition of rear remotes, purchase of a bucket, grapple, and pallet forks to add to the quick attach. I'm also sending along my curtis snow blade to have it converted over, and also add the hydraulics to make it a power angle...
Wow, did you hit the lottery? :D Don't forget the "after" photos!!!
I lifted the engine out of my Land Rover with the tractor today:cool:
   / What did you do to your tractor today? #136
I hand dug a ten foot tall `cedar`, and then with the Kubota I lifted it out of the hole, and then hand dug another hole and lowered the tree into it......hard work cutting the roots with the pick ax, and shoveling the dirt :) easy tractor stuff even though I broke a spindle off the railing for the steps....Didn`t make me mad as I did it :) Tony
   / What did you do to your tractor today? #137
What happened with an engine? Age, mileage?
I bought it as 'good' 70thousand miles and running great when taken out motor
Put it in my Land Rover and it would only fire properly on 3 cylinders
It's a 200 tdi (2.5 4 cyl Turbo Diesel)
Took motor out and found a bent conrod on No 4:mad:
Some people tell lies when selling motors, I wouldn't but some do unfortunately
Land Rover 90 ( defender) 1990
   / What did you do to your tractor today? #139
Sad story.
I had such cases with the customers while working in a position of workshop manager. It happens when engine sucks in water inside the cylinder. But usually engine even not starts after that.
In your case I would better fix an original engine or would purchase remanufactured one from certified workshop with the warranty. It's more expensive, but with minimum risk.
Try to get back to a seller and talk to him.
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
12'x20' High End Carport (A53316)
12'x20' High End...
1993 Patterson Trailer (A53316)
1993 Patterson...
2000 Ford F-250 (A53314)
2000 Ford F-250...
