John Deere 265 GT Rough Idle
   / John Deere 265 GT Rough Idle #1
LanceH
West Central Ohio
Folks, i have a 1994 (i think) John Deere 265 thats experiencing a rough idle. I'm trying to upload a video to youtube so you can hear and see it, but here's what its doing: some kind of wierd issue with the idle. I changed the battery a few months ago in preparation for winter (plowing and moving firewood) but recently it has a lope to the idle. It has to be jumped to get it started so i think its a power issue, but once its running, and the cables are removed, the lope begins. I'm thinking for $40 i should just change the battery again, but then i thought it could also be the mechanical fuel pump too.
[ame=http://www.youtube.com/watch?v=XZonLIbRmqg]John Deere 265 Garden Tractor Rough Idle Issue.MP4 - YouTube[/ame]
http://youtu.be/XZonLIbRmqg
Let me know what you think. Thanks for any advice.
   / John Deere 265 GT Rough Idle #2
I see noone has posted a response to this old thread. Maybe you have resolved the problem but I can tell you for sure it isn't the battery. I would start with a good carb. cleaning. It sounds as though it is surging/starving for fuel. This most likely is caused from a plugged jet in the carb. Make sure you have a good supply of fuel to the carb and if you do then it's time to take the carb apart.
   / John Deere 265 GT Rough Idle #3
definately carb. i had same tractor with same issue before i traded it in back in 99. My carb was far too gone becuase i cleaned it and it was till messed up. put a new carb on it and it ran good. You dont even need a battery to run that thing and wont make a difference in your idle. For the longest time, my battery wouldnt hold a charge becuase it was so bad and i would jump it using a booster pack whenever i needed it. Remeber now, your tractor and or car does not run off the battery
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
54in Loader Fork Attachment (A59228)
54in Loader Fork...
2017 John Deere 5090GN (A53317)
2017 John Deere...
