LS vs Kubota vs Bobcat hydro "smoothness"
   / LS vs Kubota vs Bobcat hydro "smoothness" #11
I echo the comments of Canada CT230. My Bobcat CT 235 is smooth as silk.
   / LS vs Kubota vs Bobcat hydro "smoothness" #12
I have the LS 3040 and have not noticed any abruptness. This is my first HST so maybe I just do not know any better.
50 hours and love the LS!
   / LS vs Kubota vs Bobcat hydro "smoothness" #13
ddb123 said:
I'll bump this up. Anybody else want to chime in on how smooth your hydrostatic operation is? I've heard that some Kiotis are a little unresponsive.
I have a dk35se kioti and have no problems with my hst. The power is smooth as it is applied and relieved in any range under any load. I test drove a kub l3800 that too had smooth hst.
   / LS vs Kubota vs Bobcat hydro "smoothness" #15
Very impressed with my Kioti HST. Very responsive, 0 noise, holds neutral, it can go from a slow creep to full in a few seconds. Reaction time is a little slow in low range but any faster you would be spinning tires or breaking parts. I do hydraulics for a living so I have a little more insight than most. So far no complaints with the Kioti/Bobcat HST
   / LS vs Kubota vs Bobcat hydro "smoothness" #16
So would you guys say that you don't have any "surging" issues? I'm going to the dealerships tomorrow to look at tractors. One of the annoyances with my tractor is that when I'm taking off I usually have to slip the clutch quite a bit to take off smoothly, and then if the RPMs are high I'll still get a bit of a lurch up to speed. This is one of the reasons I want to get a HST -- I want to go very smoothly from full stop to traveling without any lurches or jumps.
   / LS vs Kubota vs Bobcat hydro "smoothness" #17
I have absolutely ZERO lurching issues with my CT-235.
Sounds like you could have clutch issues if you are surging with a gear tractor
   / LS vs Kubota vs Bobcat hydro "smoothness" #18
It's not surging on my gear tractor, it's just that last little half inch of clutch travel when it goes into gear and takes off. It's just not the smooth engagement I want when I'm doing delicate work.
   / LS vs Kubota vs Bobcat hydro "smoothness" #19
come over to the dark side... get a hydro.. you know you want to... now is the time... just do it.:):)
truthfully you will be glad you did.
James K0UA
   / LS vs Kubota vs Bobcat hydro "smoothness" #20
James K0UA
James, I think now IS the time, you are right. The question is which tractor, but I am ready for HST and 4x4. Hey, I see you updated your signature. Did you get your new tractor yet??
2014 Ford F-150 Ext. Cab Pickup Truck (A52377)
2014 Ford F-150...
CAT 938G Wheel Loader (A47477)
CAT 938G Wheel...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
1990 LOAD KING BELLY DUMP (A53843)
1990 LOAD KING...
GRACO KING XL70-180 TANK LINER APPLICATOR (A53843)
GRACO KING...
