F-150 Eco Boost Towing Vs Nissan Titan
   / F-150 Eco Boost Towing Vs Nissan Titan #51
I will redo the math again then using 18 mpg and 15.5 mpg.
I come up with a savings of $5376 using $4.00 gas and $6720 using $5.00 gas.
Using 19 mpg and 16.5 mpg.
Savings of $4785 using $4.00 gas and $5981 using $5.00 gas.
Sounds like a wash to me in the end. Pick the one you like best because the ownership cost are roughly the same. I know someone will now jump in and say that the direct injection and turbos will go out before it reaches 150,000 miles which is speculative. I think the maintenance cost will be about the same.
You are a stickler for details, throw in the 3.5% interest amortised over 10 years that I get in the account I mention, (and assuming that I pulled out all of my fuel expenditures from the account), and at the $4.00 gallon I quoted, I will be very close to that $1000 figure if not slightly over.
I did not mention the maintenance items that you did, but you are correct that if those turbos give out, or it would break an exhaust manifold bolt like Fords have been prone to, then I come out way ahead.
   / F-150 Eco Boost Towing Vs Nissan Titan #52
I do like to debate the details. Just making a point that the overall price difference is negligible. I haven't heard of the exhaust manifold issue with the ecoboost, could you please explain? Is there something I should be watching for? As far as maintenance, again I would consider the reliability edge to be maybe slightly better for the ford but time will tell. I still think chevy has both beat on reliability. I know JD Powers hits the Ram pretty hard for reliability numbers.
rockshaft said:
I'm sure that was a fun rig going down some of the steep grades on this route as well:)
Best unloaded mileage I can get out of my Titan is about 16mpg, if I nurse it super easy. I leave it parked under the carport as much as possible! I *do* appreciate it when I need to haul loads though. I haven't experienced any of the newer Ford/Chevy/Dodge, but when I looked at them in '06 I found the Titan had the kindest ride and a very comfortable cabin for me.
Its funny you say the Titan has a kind ride. Maybe its my dealer installed 2" lift but compared to the 6 F150's I have owned my Titan is more like a 3/4 ton.
Chris
   / F-150 Eco Boost Towing Vs Nissan Titan #54
Chris
Definitely the nicest ride of a truck I've owned. A little less so now that I've added air bags on the rear axle, but still pretty darn good. IME, lifts can have a deleterious impact on ride.
   / F-150 Eco Boost Towing Vs Nissan Titan #55
I am currently a "phord phan", whatever that means?
When the cutesie pie spelling comes out it means that you had the audacity to not have the same opinion as dmace.
Mention the government bailout of Chrysler if you really want to make him mad. :confused2:
And now, I'm off to sunny Florida for a spell!
   / F-150 Eco Boost Towing Vs Nissan Titan #56
I cannot argue that the overall cost of ownership is negligible, depends on each situation. If not for the fact that I was able to get significant savings on the Ram vs the Ford, the picture could look different.
Ford has had exhaust stud and spark plug issues with about every variation of engines in the Triton group for years, I do not know if they have addressed those issues on current engines, but if history is any indicator....
You are also correct in that Ram had quality control issues also in the past. But I gotta tell you I crawled under this truck from bottom to top and it appears as if they have done some serious upgrades. I was impressed enough to give one a try and so far I am still a happy guy.
A couple of things: The Eco cannot come close to matching the feel and sound of that Hemi. Ram has the best ride of any 1/2 ton out there by far with the coil setup, that is something I appreciate every time I drive it.
   / F-150 Eco Boost Towing Vs Nissan Titan #57
I've only driven one Titan and that was the first year they were out and a brother-in-law had bought one. It just happened that I had recently driven a new Ford F-150. Personally, I'd buy the Ford over Nissan, but as for just the "feel" of the two vehicles, acceleration, steering, seat comfort, sound level and such, there just really was not enough difference to tell it at that time.
   / F-150 Eco Boost Towing Vs Nissan Titan #58
Diamondpilot said:
This Eco Boost is in its first version and is already very impressive.
Give it a chance instead of instantly writing it off.
What about this engine is "very impressive"?
It makes the same power and fuel mileage as its V8 competition only cost more and is a TON more complicated. Now if this engine were normally aspirated or made V8 power with much better fuel mileage then I would be impressed.
Diamondpilot said:
Not a single one. But look at the weights of a 2003 Dodge 2500 gasser versus say a newer 1/2 ton and there is very little difference. And this newest model of the GM trucks will be built just as heavy.
Do you actually believe an F150 and F250 will both get the same mileage with 5.4l's just because the weights are close?
It's not just about weight, it's also gearing and drivetrain setups. Your comparing 1/2 tons to a heavy duty 3/4 ton, I'm not surprised you left that out...
I'm still not impressed, if this had been a test between the Ecoboost and ANY other V8 half ton truck instead of one with the worse fuel mileage in it's class, the numbers would have been closer. So this Ecoboost does nothing more than any other decent V8. It's a start but still a long ways away from impressive...
   / F-150 Eco Boost Towing Vs Nissan Titan #59
When comparing fuel mileage, the EPA is the only accurate measurement for comparison since all the vehicles go through the same exact test. Real world numbers aren't that accurate as one guy on the flat south driving like grandpa could get 20 mpg where another guy with the same vehicle could get 15 mpg in the same area.
Ok here are your EPA ratings that you requested. I will use 2wd to keep things simple.
Ford ecoboost: 16/22 365hp/420lbft
Ford 6.2 liter 13/18 advantage ecoboost 411 hp/434 lbft
Ram 5.7 liter 14/20 advantage ecoboost 390 hp/407 lbft
GMC 6.2 liter 13/18 advantage ecoboost 403 hp/417 lbft
Nissan 5.6 liter 13/18 advantage ecoboost 317 hp/385 lbft
Toyota 5.7 liter 14/18 advantage ecoboost 381 hp/401 lbft
Average all 13.4/18.4 380.4 hp/408.8 lbft
Now for the V6 engines
Ford 3.7 liter 17/23 disadvantage ecoboost 302 hp/278 lbft
Dodge 3.7 liter 14/20 advantage ecoboost 215 hp/235 lbft
GMC 4.3 liter 15/20 advantage ecoboost 195 hp/260 lbft
Toyota 4.0 liter 16/20 advantage ecoboost 270 hp/278 lbft
Average all 15.5/20.75 245 hp/262.75 lbft
http://www.fueleconomy.gov/feg/pdfs/guides/FEG2011.pdf
So it gets 2.6/3.6 better than the average V8 and .5/1.25 better than the average V6. In fact, the only engine that bested the ecoboost was Fords 3.7 liter V6 so it actually gets better EPA ratings than a typical V6.
I know, still not impressed because it is a TON more complicated. I guess one needs to ask, what would impress you? 5mpg better? 10 mpg better?
Jeff
   / F-150 Eco Boost Towing Vs Nissan Titan #60
Ram 5.7 liter 14/20 390 hp/407 lbft
Yeah, still not impressed.
Although, that HEMI still looks great making more power with a tried and true simple engine running over 9 years now of proven reliability yet only given up 2 mpg average. Considering there's no turbos or direct injectors to worry about is the icing on the cake. With the new 8 speed auto, that HEMI will match or beat that 16/22 mpg, then I will be even more unimpressed. :laughing:
Also, you should show the Ford V8 5.0l to really make the Ecoboost look unimpressive...
Ford 5.0 liter 15/21 360 hp / 380 lb.ft.
Now that 5.0l from Ford DOES impress me.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53472)
2019 Ford F550...
2025 New/Unused Min Skid Steer Loader (A51573)
2025 New/Unused...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
