my deck/patio project
   / my deck/patio project #41
Thanks for the pictures
No roof over the deck but the patio area will have a pergola over it.
I felt that I should explain this comment, I made in a earlier post.
we have decided to go with a roof after all,this will allow us to sit outside
while it is raining.
   / my deck/patio project #43
Sounds like your plan is evolving and you're bringing it up a notch the more you get into it!!!!!
Eddie
I was able to get most of the decking down, even though the weather has not been the best.I hope to get more of it done tomorrow.
This weekend I will place the beams that run parallel to the deck(provided we get no rain).
I think I will drink my morning coffee on the deck this weekend. :)
   / my deck/patio project #45
It looks good. :thumbsup:
I'm getting ready to screw down the deck planks on my son's new tree house. What spacing did you use between your deck boards?
None ,the boards will shrink as they dry out, causing gaps.If you want to gap them,about a 1/8" is all you should need.
I did get 4 of the beams in place tonight ,will post pics tomorrow.
Beams
   / my deck/patio project #49
Are you using 4x4's for the beams? What is the span between posts?
You really need to do a google search for span tables. They list the size of lumber that you need to go a certain distance to support a load. Seeing that you are in Ohio, I'm going to assume that you get snow. A flat pitch, with snow sure sounds like you want to over build, and not cut any corners on undersizing your beams.
Eddie
Eddie
This should give you a better idea of how I will be doing the roof.
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
2022 CATERPILLAR 302.7 CR EXCAVATOR (A52707)
2022 CATERPILLAR...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A57193)
UNUSED...
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
Ford 8510 (A53317)
Ford 8510 (A53317)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
