how to search on TBN??
   / how to search on TBN?? #1
HCJtractor
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
Dumb question, but is searching for a particular phrase or group of words, how do you keep the search engine from splitting them? For instance, I did a search for "cover chains" and it shows "cover" and "chains" but that is not the result I need. I remember reading there is a way to make sure the phrase stays together in a search. Thanks.
   / how to search on TBN?? #2
In most search engines, putting that combo in quotes would do it.
There was a tip this past week about using Google to search a specific website, like TractorByNet, which they thought worked well. Don't have the format in front of me, but it used a : and the web address... try searching for searching... :)
   / how to search on TBN?? #3
here is the posting-- <http://www.tractorbynet.com/forums/showthread.php?p=2819844#post2819844>
   / how to search on TBN?? #4
Using google, type
"cover chains" :TractorByNet.com | Compact Tractors | John Deere, Kubota, New Holland
The quotes will mean the two words have to appear together. I haven't found a way you can do it using the native search function of this site, but maybe someone else knows how it can be done.
   / how to search on TBN?? #5
   / how to search on TBN?? #6
I found another format listed elsewhere which seems to work, and is more intuitive... put the site name first, like this:
site:tractorbynet.com, "cover chains"
It did only come up with tractorbynet listings...
Paul
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
500BBL WHEELED...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2017 BX2680 Sub Compact Utility Tractor (A56438)
2017 BX2680 Sub...
