New skid steer change over on Koyker 160 on its way
   / New skid steer change over on Koyker 160 on its way
I was wondering about that & started to ask if you were sure about the OE size. I figured it was your tractor & you knew what you had. :D Mine are 12.4x11x28 also 7x16 on the front
Yeah it was typical me-typing one thing and my mind being somewhere else. :D :laughing:
   / New skid steer change over on Koyker 160 on its way #22
Looking forward to hearing how you like the SSQA. I have a skid steer myself and having the ability to remove my bucket in seconds sure is slick. :thumbsup: From personal experience with both pallet forks and a grapple, the best combination is pallet forks with a single grapple thumb, so much more versatile. :thumbsup:
Thanks for the insight sounds great! I am thinking there will be more projects than I know that will come up there usually is when you buy a new attachment. :D
update on ETA: I guess from what I gathered from the call I made to the JD dealer they had my pallet of parts end of last week already! And no one but the mechanic that off loaded it knew about it that figures I knew something was wrong its only 450 miles! :mad:
They are making it up by meeting me half way so that saves me time and I appreciate the thought. Fact I am waiting on their driver to call me at any time now this morning so I can run over there. :thumbsup:
Parts are here and look correct so once I get done with the truck I am fixing the a/c on I will bring it all in and take some before pics. :D
   / New skid steer change over on Koyker 160 on its way #25
o.k. CarDoc I am taking your advice and will take two-beers and wait til you post some pics.....love to see new parts,barckets and the like. I hope you like the finished project as my 336 may also get a quick plate once you have yours working.......
Although that may require two additional beers.............................................
Well as promised here are some before and after pics of the QA skid steer attachment with pallet forks. :D
Of course the first job was to see if I could lift and move those big pallets of firewood. :thumbsup: (and thats about all the weight this tractor wants to lift safely)
Cutting the mount off my bucket is next and them welding the skid steer plate on it. I have concerns about whether I will lose some of my rearward curl if the plate is mounted flat to the backside of the bucket.
Reason I say that is the forks have no rear curl as is and I dont know what to think about that...designed in or what. It lifts at a slight negative forwards angle and about 1 foot off the ground levels out so thats why I am reserving my thoughts on it for now.
And will do the head scratching on the bucket later today or tomorrow I need to cut the bracket off first, I definitely want to keep my full arc.
   / New skid steer change over on Koyker 160 on its way #28
... the forks have no rear curl... It lifts at a slight negative forwards angle...
Could you weld a 'heel' to the back of each fork, down where it rests against the QA plate? That would raise the tips of the forks.
That looks like a great rig. I envy you guys with state of the art equipment!
Now thats good thinking California a great idea I just may use it thanks! :thumbsup:
   / New skid steer change over on Koyker 160 on its way #30
Shiny paint, new tires, quick attach bling.. what's next, a gimbal mounted seat? :D
You're putting together the perfect rig. What will happen when you run out of things to improve? ..wait, is that even possible? ;)
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
2008 JLG 600S TELESCOPIC MANLIFT (A51242)
2008 JLG 600S...
Case IH 8610 Tub Grinder (A50514)
Case IH 8610 Tub...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
UNUSED FUTURE EQUIPMENT SEAT (A51244)
UNUSED FUTURE...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A52128)
2014 Ford F550 4x4...
