3 Point Attachment Switching not enjoying.
   / 3 Point Attachment Switching not enjoying. #62
   / 3 Point Attachment Switching not enjoying. #63
You have choices:
1. Modify all of your implements to fit the framed QH. Lots of welding, bending, adjusting, and adding materials. When you get a new implement it likely will have to be modified as well.
2. Forget the QH and go back to manual hook-up. It will go faster with practice.
3. Spend a fortune and get the Deere I-Match. Figure to spend more for each attachment.
4. Get a Pat's Easy Connect and be done with it.
   / 3 Point Attachment Switching not enjoying. #64
Ok, did my first change out today of attachments (Box Blade to 3 Pt Receiver Hitch). Just a quick briefing I am new to SCUT'S and 3point attachments! Ok is it really as much as a pain as I just experienced? I figured you pull the pins drive off attach the next. Seems like you have to twist turn and maneuver your attachment to get weight off of the pins. Am I missing any tricks? Should I be running out for this iMatch system? Doing all kinds of stuff around the house. I want to be able to be box scraping, be done with that, throw the 3 point receiver hitch on to trailer stuff around the property, quickly switch over to a heavy ballast to start moving boulders.
Just not looking to break down a schedule on when I am doing what because that attachments aren't as easy to get off as I thought. And I could see myself saying "Man I'm not dealing with switching out attachments, I'll do that next week."
Don't you like to use loud foul language and kick sh*t of the thing sometime.
Alexander Equipment - Founder of the Delta Hook Rapid 3 Point Hitch System is the least pain if you have the money to buy adapters for your implements.
   / 3 Point Attachment Switching not enjoying. #65
Greasing the ball ends in the lower links helps me. Having a 3-pound hammer and a 4' long crowbar helps me. Being on relatively flat ground helps me. Doesn't mean it's not a pain in the rear, but at least it's a pain that only lasts five or six minutes.
Haven't gotten around to it yet, but sooner or later I imagine I'm going to make myself some dollies. The idea of just rolling the implement into place behind the parked tractor sure sounds good.
xtn
   / 3 Point Attachment Switching not enjoying. #66
Was out wrestling a post hole digger the other day.:laughing: The foul language was flowing... for a good 20 minutes.. I'm sure I pulled my back out fighting that thing.
I think I might have found the trick is to drill it in the ground standing upright and unhook it.. and then it'll be less of a bear to get on again..
I tried talking my wife into just letting me buy a tractor for each implement :laughing:..
   / 3 Point Attachment Switching not enjoying. #67
Well I don't need the practice hooking up implements to get better at it I have been hooking up 3pt implements since I was 9 yrs old or younger (like 44 + or - years) so that's not going to get any better.
I am not going to weld, bend, cut, adjust, and modify, to the extent you are talking at least. Some modifications are ok, but too many just don't seem worth it.
I don't have a concrete area to use dollys as suggested.
I guess pats type connections are the only way unless I stay with what I have the old fashion back up, push, pull, pound, cuss and so on. I just wanted to know which way I was going to go before I bought the hydraulic center link because if I go with the pats it will change.
   / 3 Point Attachment Switching not enjoying. #68
The Carters work pretty well too.. I have a set for sale. I don't need them any more after getting the Kioti with the telescoping links and side sway adjusters. Also you could make a set pretty easy if you can work 1 inch thick stock.
James K0UA
   / 3 Point Attachment Switching not enjoying. #70
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
2008 Jeep Patriot Sport SUV (A50324)
2008 Jeep Patriot...
2018 Bobcat T595 (A50120)
2018 Bobcat T595...
40' CONTAINER (A51244)
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
